Rotor surface cracks after HPDE? a concern?
Old May 14, 2009 | 03:25 PM
burntZ's Avatar
burntZ
Default Rotor surface cracks after HPDE? a concern?
rotor is <1 year, ~ 12k miles, [~850 track miles]
from centric / zeckhausen so should be good / brembo sized 1 piece
lots of shallow? surface cracks / 'crazing' - more noticable after trackday last sat.
no significant thickness wear, only on both fronts, both rears look normal shiny / smooth
any thoughts? impending rotor detonation or just normal overheated rotor?
Thanks!
and for your entertainment
getting turn 1 wrong (circa 2006, sebring)
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i334.photobucket.com/player.swf?file=http://vid334.photobucket.com/albums/m410/alfajimBBK/100_0816.flv">
5/9/9 fastest lap 2:44
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/2Io2wfY4gog&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/2Io2wfY4gog&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Old May 14, 2009 | 03:33 PM
terrasmak's Avatar
Looks normal , and still usable
Old May 14, 2009 | 03:37 PM
mthreat's Avatar
mthreat
People have told me it's normal. I've been told that once enough of the tiny cracks line up, they'll eventually form a bigger crack, and then the rotor will "crack" in the usual sense. Then it's time to replace it
You could ask Zeckhausen, they have always been very knowledgeable and helpful for me.
Old May 14, 2009 | 04:01 PM
Looks superficial. Expansion contraction from heat cooling. Keep an eye on them and see if it gets worse.
Old May 14, 2009 | 06:23 PM
Ruthless18x's Avatar
Ruthless18x
Looks normal. I've seen some guys rub sand paper on their rotors right after a run and swap race pads to street. I haven't done it but supposedly it cleans them up a bit.
Maybe somebody could comment?
Old May 15, 2009 | 06:31 AM
burntZ's Avatar
burntZ
Thanks, ignoring it for now was my main plan, but, i didn't want bits of rotor falling off...
Old May 15, 2009 | 08:08 AM
bryan@Z1's Avatar
bryan@Z1
Vendor - Former Vendor
I got this info from Baer several months ago when asking them about this same condition. This was a TSB from GM regarding Corvette rotors.
Bulletin No.: 05-05-23-007
Date: August 03, 2005
INFORMATION
Subject:
Information on Visual Brake Rotor Surface Cracking
Models:
2005-2006 Chevrolet Corvette
with Heavy Duty Brakes (RPO J55)
Important: DO NOT replace OR resurface rotors for small surface cracks that are described below.
The pass criteria for thermal fatigue testing specifies that the rotor is allowed to have small thermal cracking up to 2/3 of the brake plate surface. The brake plate surface for the front rotor is 50 mm (1.96 in) radially which means cracks are permitted up to 33 mm (1.29 in) radially across the rotor brake face in length. This would be the pass criteria for the end of severe testing. To have a large safety margin, a rule of thumb - small thermal cracks are allowable and the rotor does not need to be replaced unless the cracks connect from hole to hole or the crack reaches the OD of the rotor.
Old Oct 5, 2009 | 04:07 PM
burntZ's Avatar
burntZ
slight update
went with ignoring the tiny surface cracks
but was hard to ignore this!
did ~44 laps sunday 10/4/9 at sebring from 9-12 - normally get 60-70 laps in full day so was on record pace)
stopped for lunch and found this (was slightly smaller there - took pics today at home)
needless to say i stopped and gingerly drove home!
<a href="http://s334.photobucket.com/albums/m410/alfajimBBK/?action=view&current=cracked1.jpg" target="_blank"><img src="http://i334.photobucket.com/albums/m410/alfajimBBK/cracked1.jpg" border="0" alt="Photobucket"></a>
closeup...
<a href="http://s334.photobucket.com/albums/m410/alfajimBBK/?action=view&current=cracked3.jpg" target="_blank"><img src="http://i334.photobucket.com/albums/m410/alfajimBBK/cracked3.jpg" border="0" alt="Photobucket"></a>
new rotors ordered - have 1 oem front caliper / rotor on at the moment
had a couple of increased pedal movement corners but no noticable judder or noise - i just allways do a close walk around inspection while waiting for the lunch hour to go by... and i will keep doing it to!
Old Oct 5, 2009 | 04:56 PM
aloh's Avatar
aloh
jeez... thats a major crack.
What rotors did you go with?
Old Oct 5, 2009 | 05:58 PM
burntZ's Avatar
burntZ
Products
1 x StopTech SportStop slotted rear rotor 322x22mm, Right $109.00
1 x StopTech SportStop slotted rear rotor 322x22mm, Left $109.00
1 x StopTech SportStop slotted front rotor 324x30mm, Right $119.00
1 x StopTech SportStop slotted front rotor 324x30mm, Left $119.00
from zeckhausen.com
the rears are fine just not sure how slotted in front / plain rears would look - might not change the rears for 3-4 more hpdes
the cracked one was from zeckhausen also- the plain centric rotor - it had ~6-7 hpdes use on it and to be completely honest i had seen a suspicious pre crack when changing the brake pads and ordered the new rotors last friday - didn't really expect this though - the 'pre-crack' was just a heavier surface crack but didn't reach to the edge of the rotor (then!)
my thoughts are that the slotted rotors will keep the temp down enough to (hopefully) avoid this - might finally do some brake duct work also - allways meant to just never got around to it...
Old Oct 10, 2009 | 11:49 AM
burntZ's Avatar
burntZ
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf?file=http://vid334.photobucket.com/albums/m410/alfajimBBK/Turn17FAILsmall.flv">
Sebring Turn 17 10/4/9
braking from ~125 to 90 at the corner
& not getting it quite right....
I haven't done that since 2006, here at turn 1...
braking from ~110 to 75 at the turn in
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf?file=http://vid334.photobucket.com/albums/m410/alfajimBBK/100_0816.flv">
is unrelated to the broken rotor but didn't really need it's own thread...
Old Oct 10, 2009 | 12:16 PM
SniperHunter's Avatar
SniperHunter
Wow, and you couldn't notice it when driving? Very curious how something like that feels to be driven with. Hehe.
Old Oct 10, 2009 | 12:30 PM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
I have the same rotors I purchased from a member here and noticed they are doing the surface cracks as well.
Old Oct 10, 2009 | 06:07 PM
burntZ's Avatar
burntZ
it wasnt quite that bad at sebring - sometime between the 130 mile drive home / 40 miles next day until went to change pads it fractured completely rim to hub
nope never even a judder - weird - possible that the tire held it together until i loosened the lugs and then it popped the rest of the way, it was out of view until the wheel came off
SOLO-350Z I have the same rotors I purchased from a member here and noticed they are doing the surface cracks as well. .\
the same rotors that cracked or the same rotors i just bought? - either way i'll be keeping a bit closer eye on brake rotors from now on.
i plan on keeping current rears for track spares and in ~9 months (1/2 current rotor life) i'll order a new set to have on hand.
anyone know if the 2 piece rotors last longer than 1 piece? would have to last ~ 3 times as long to be "economical" [cause i'm cheap and it's a hobby]
Old Oct 11, 2009 | 02:29 AM
turtleboy's Avatar
turtleboy
wow, I think my stock rotors should last a little bit longer
Old Oct 11, 2009 | 07:47 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
I bought these slightly used off another member but the same ones you got. centric blanks. They showed the surface scratches after one track event. I did another and now they are vibrating pretty good. I am swapping them back out today with my stock ones as I have no track events coming up right now.
Old Oct 11, 2009 | 07:53 AM
slight update
closeup...
You killed the brake rotor!
Twenty4
Jan 17, 2016 01:20 PM
Depravity
Oct 1, 2015 04:49 PM
samansharif
Sep 25, 2015 12:31 PM
