Z33 with Z32 calipers....
Old Mar 16, 2009 | 05:20 PM
Geox1's Avatar
Geox1
Default Z33 with Z32 calipers....
Alright ladies and gents i know there is already a thread to this topic already about putting z32 brake calipers on a z33.... its a good up grade from the stock one piston calipers to four pod calipers.... Ill keep u posted on this, if u want to share any info. let me know... Im still working on my convertion.... I did it but there is lil issues i need to fix.... and trust me those calipers work better than the stock calipers....
Old Mar 16, 2009 | 05:22 PM
huyrua's Avatar
huyrua
Interesting
Old Mar 16, 2009 | 05:38 PM
DavesZ#3's Avatar
DavesZ#3
Possible? Maybe
Good idea? Probably not
Worth the time and money? Likely not
There are a dozen threads on the subject here - the concensus of which is it's not worth it.
It will be interesting to see your final product.
Old Mar 18, 2009 | 07:13 PM
Geox1's Avatar
Geox1
wow there is LOTS of negativity here.... well just to let all the people that think that its not possible.... I've got it done..... if you got the right parts and the creativity to do it you own everything...
Old Mar 18, 2009 | 07:18 PM
Geox1's Avatar
Geox1
its the same as the brembo system.... im just making ma car look original with original parts from NISSAN.... not brembo (the cost of brembo is way to expensive) you can get a set of Z32 calipers for cheap....
Old Mar 18, 2009 | 07:21 PM
Flee0588's Avatar
Flee0588
You had one negative response and one "interesting".
Old Mar 18, 2009 | 07:23 PM
Flee0588's Avatar
Flee0588
Btw, post pics of them on your car please. I want to see. Also what "issues" are you working out?
Old Mar 18, 2009 | 07:26 PM
Geox1's Avatar
Geox1
Old Mar 18, 2009 | 07:34 PM
Geox1's Avatar
Geox1
https://my350z.com/forum/members/geo...one-piston.jpg
Old Mar 18, 2009 | 07:35 PM
Geox1's Avatar
Geox1
sorry that pix is small...
Old Mar 18, 2009 | 07:36 PM
Geox1's Avatar
Geox1
FROM THIS.... https://my350z.com/forum/members/geo...one-piston.jpg
TO THIS.... https://my350z.com/forum/members/geo...od-caliper.jpg
Old Mar 18, 2009 | 07:38 PM
Geox1's Avatar
Geox1
and now rolling on it.....https://my350z.com/forum/members/geo...ling-on-it.jpg
Old Mar 18, 2009 | 07:39 PM
Flee0588's Avatar
Flee0588
k
Old Mar 18, 2009 | 07:48 PM
Geox1's Avatar
Geox1
https://my350z.com/forum/members/geo...ure13045-a.jpg
Old Mar 18, 2009 | 07:50 PM
SchismX's Avatar
SchismX
Doesn't really seem worth it. I bet they really don't perform much better than the one piston z33 brakes.
The rotors look smaller than stock.
Old Mar 18, 2009 | 07:57 PM
Geox1's Avatar
Geox1
thats ma lil issue im working on im going to put a 13 inch rotor on it....
Old Mar 18, 2009 | 08:02 PM
Geox1's Avatar
Geox1
sure thats what you think.... just on the upgrade of the master cylinder from a non brembo to a brembo. even just the master cylinder makes a lot of difference the bigger master cylinder more fluid gets pump.....
Old Mar 19, 2009 | 03:04 AM
DavesZ#3's Avatar
DavesZ#3
Dude, do it then post results. You're wasting bandwith with a stream of one-line meaningless posts.
Old Mar 19, 2009 | 04:48 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Last I checked the Z32 rotors were smaller than the Z33. So it would be a downgrade.
Old Mar 19, 2009 | 06:05 AM
drifter5's Avatar
drifter5
It is smaller.
350Z 2003-Up (Z33, non-track)
296mm x 24mm Rotor
350Z 2003-Up (Z33, Track)
324mm x 30mm Rotor
Z32 26mm Aluminum (1990 NA 300ZX)
280mm x 26mm Rotor
Z32 30mm Aluminum (1990-1992.5 Turbo 300ZX and 1991-1992.5 NA 300ZX)
280mm x 30mm Rotor
Z32 30mm Iron (1992.5-1996 Turbo and NA 300ZX)
280mm x 30mm Rotor
