Toe keeps going out!!
Old Mar 22, 2009 | 07:20 AM
aarantes's Avatar
aarantes
Default Toe keeps going out!!
Hey guys,
I have been lowered on Tein Mono Flex for about a year now and got an alignment since my KDW finally went(they were just to loud for daily driving). I have an Ichiba chamber kit installed but the only problem is that my toe keeps going out. The alignment was perfect when I left 1000 miles later my new tires were gone so I got new ones and sat there to watch the alignment guy do my alignment, to make sure it was done right. Yet 4 days later my toe is out again and they don't know why
Any help would be appreciated!!
Thanks
Alex
Old Mar 24, 2009 | 04:23 AM
aarantes's Avatar
aarantes
Bump...
Old Mar 24, 2009 | 10:02 PM
thinking's Avatar
thinking
You did not mention if this was for the front or the rear.
If you are referring to the front, toe is still adjusted in the stock location; the Ichiba A-arms are not used to adjust toe.
Old Mar 25, 2009 | 03:54 AM
aarantes's Avatar
aarantes
Opps sorry it is in the rear.
Old Mar 26, 2009 | 08:19 AM
Thermal1's Avatar
Thermal1
He didnt tighten it down after he adjusted it? That happened to me once.
Old Mar 27, 2009 | 05:45 AM
aarantes's Avatar
aarantes
No I had it redone and it's still going out. Is there any bushings I should be checking? I have ordered the spc toe bolts in hopes that will fix it.
Old Mar 29, 2009 | 03:52 AM
OSIRIS06's Avatar
OSIRIS06
rear toe will not go back into spec when replacing just the rear caber arms, you will need the spc or who evers larger eccentric bolts to do so
Old Mar 29, 2009 | 06:32 AM
aarantes's Avatar
aarantes
Yeah I just got my SPC toe bolts in so we will see if that will work
Old Mar 29, 2009 | 09:11 AM
terrasmak's Avatar
If i remember right , Ichiba camber arms have bushing problems always change the alignment.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
N74DV
May 4, 2003 09:42 AM
jelledge
Jan 31, 2003 07:29 AM
droideka
Nov 27, 2002 12:02 AM
