Camber kit Question
Old Mar 22, 2009 | 10:18 AM
Mustlistenfc's Avatar
Mustlistenfc
Question Camber kit Question
I'm looking for the spring (Eibache prokit or Tanabe gf210), do you think, do I need to install the camber kit too ? when I install springs or after ?
I don't know, how much I can drop with the stock camber kit
Old Mar 24, 2009 | 12:46 AM
Jarrod's Avatar
Jarrod
Help, this is a question I was wanting to know as well. thanks
Old Mar 24, 2009 | 06:26 AM
tally350z's Avatar
tally350z
It would probably be best to install the kit while you are getting the springs installed at least in the rear. Not to difficult to do.
Old Mar 28, 2009 | 07:27 PM
OSIRIS06's Avatar
OSIRIS06
i just install the eibach sportline on my 06, which gives you a 1.2" drop, now if you don't care about your tires, ROCK OUT!!!,
i work at a dealership so i do my own work, with out adjustable camber arms, factory adjustments only let you get -2.25 to -2.50 you cant go any more positive than that, you can get you rear toe adjusted in with factory adjustments, if you do get aftermarket caster adjustments for your rear make sure you get something to help with rear toe also and for the front there is no camber adjustment i'd def. recommend front upper arms
issyz
Jul 2, 2017 03:04 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
