Vlsd problem?
Old Mar 22, 2009 | 10:29 AM
Mustlistenfc's Avatar
Mustlistenfc
Question Vlsd problem?
I feel like my stock Vlsd doesn't work anymore... do you know how to check the vlsd work or not easily?
Old Mar 22, 2009 | 11:34 AM
tiguy99's Avatar
tiguy99
What do you mean doesn't work? Can you elaborate more? What are the symptoms?
Old Mar 22, 2009 | 12:18 PM
Mustlistenfc
When I increase RPM really quickly (when driving in a straight direction) and lose traction, the rear side of my car swirves to the left or to the right.
Is it even possible the VLSD to break?
Also, I noticed I don't have much grip left on my tires... Does that make a difference?
Old Mar 22, 2009 | 12:20 PM
davidmcc's Avatar
davidmcc
Also, how many miles are one the car? a lot of hard driving?
When vlsd's fail they usually end up operating as an open diff. I know it's not very technical but the easiest way I can think of to test it would be to do a burn-out and see if you leave one tire mark or two
Old Mar 22, 2009 | 12:27 PM
davidmcc's Avatar
davidmcc
sounds like you just need new tires
Old Mar 22, 2009 | 01:20 PM
aarantes's Avatar
aarantes
I hope this is a joke
Old Mar 22, 2009 | 01:58 PM
Mustlistenfc
I understand the car would swirve a little bit when the tire has little grip but with VLSD shouldn't it keep the car straight?
Old Mar 23, 2009 | 03:04 AM
Z04's Avatar
Z04
LSD is only useful in curves, not the straights. if you are losing traction while going straight it is your tires
Old Mar 23, 2009 | 08:16 AM
Gsedan35's Avatar
Gsedan35
The following cut and paste exchange from another thread is for the OP and in responce to your post.
Originally Posted by scotts300
I'm at 55k, and Nissan FINALLY agreed to replace my aging VLSD. It's a long story, but my car will burn the inside tire during a slightly aggressive turn. The local dealership said I was overdriving the car, and that what I was experiencing was normal. I refused to agree.
The final word from NNA was that the differential had to be able to hold 90#-ft of torque with one wheel fixed/on the ground. I've tried this at home many times, and the breakaway torque is about 5#-ft. The Z goes in Friday for them to confirm the breakaway torque of my diff, and replacement from there.
Originally Posted by Gsedan35
Remember, VLSD does not prevent wheel spin from occurring. Once a wheel spins free, the viscous flud attempts to rain in the offending wheel by offering what the tech say's is 90 ft lbs of torque. It is not a proactive system like other LSD's. Since it's on topic I'll cut and paste the following post of mine.
The VLSD unit consists of stacks of thin plates with holes or slots, all suspended in a special silicone fluid. They have no clutches to wear out, and locking characteristics can theoretically be changed by varying fluid viscosity. Generally, however, these units are non-serviceable, and require no special maintenance. As the differential spins, the plates shear the fluid up to a point, after which the fluid provides some resistance to shear, allowing 15-25% torque transfer to the other wheel. The downside is that these units don't act like a limited slip until one wheel actually starts slipping (i.e., they don't prevent slippage), which means the VLSD action often kicks in after you've already exited the corner. Compared to the proactive nature of the Torsen LSDs, the VLSDs are reactive units. They do not prevent slippage, they merely sense differences in rotation, not torque. They also don't allow for very much torque transfer, compared to mechanical or clutch-pack LSDs. They do still work well for starting from a dead stop in slippery conditions. It is important to note that VLSDs locking characteristics occur both during acceleration AND braking, as it can't tell the difference between the two, but merely reacts to the rotational speed differences between the two drive wheels.
Old Mar 23, 2009 | 08:21 AM
haulwrecks's Avatar
haulwrecks
tire pressure check them
Old Apr 1, 2009 | 07:16 AM
SnyperZ's Avatar
SnyperZ
To your original question..if your a$$ end is going sideways that means both tires are spinning which means its actually working. When you spin the tires and the car just kinda goes straight thats when its broken.
Old Apr 1, 2009 | 08:20 AM
terrasmak's Avatar
How many miles? Its probably trash anyhow , they have a usable life of around 60k miles
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
