Rear Tow Question
Old Mar 25, 2009 | 07:07 AM
Kiriller's Avatar
Kiriller
Default Rear Tow Question
Hey guys i have an 07 Z, something happened when the previous owner had it and now it has a negative (-1.3) tow and thats the maximum it can go. Im lookin at a SPC extreme toe kit that allows adjustment from -3 to 3. Do you guys think this kit will fix my problem ?
Thanks in advance.
Old Mar 25, 2009 | 08:30 AM
Done Deal DR's Avatar
Done Deal DR
It's "toe" and given their aren't any major suspension issues and you just need the ability to get it within spec, the SPC kit that has both camber and toe adjustments should do the trick. Obviously the real answer here is to take it to the alignment shop and ask them. I'm assuming your Z is lowered?
Old Mar 25, 2009 | 12:31 PM
Kiriller's Avatar
Kiriller
Not lowered. Took it to the shop they didnt find the problem, then i went to nissan, they charged me an arm just to check and said that i need to change the drum (aliminum thing that holds the spring, 2 arms and some other part. (they are offcource assuming what needs to be changed) But my idea is to get after market toe arm and just straight it out - seeing how they can go from -3 to 3. Any thoughts?
Old Mar 29, 2009 | 03:36 AM
OSIRIS06's Avatar
OSIRIS06
unless you hit something or you warranty is out by milage, that eccentric bolt should be covered, im a mechanic i just lowered my z this week and i could still get my toe back into spec with out a toe adjustment kit, i need a camber kit to be able to get camber where i want it, and will have to do a toe kit then.
416blueZ
Jun 11, 2024 10:56 AM
PLAYDIRTY
Oct 12, 2015 07:45 AM
ILoveDrifting
Sep 7, 2015 03:15 PM
