How do I do it?
I've googled but I dont have a c-clamp. I also used a flat blade before on oem's and while it jacked my pads it did work, i cant afford to screw up my pads this time and these aint oem calikpers i'lkl risk it on.
thanks
thanks
Buy a c-clamp. They are like 3 bucks at harbor frieghts or even home depot they are cheap. How can you afford a 4 pot caliper and not afford a c-clamp is beyond me. That's called irony.
Before you use your c clamp make sure you have brake cleaner and blast out all the nasty grut so you dont score anything
I wouldn't pay $225 for this, but this looks like the perfect tool:
http://www.zeckhausen.com/StopTech/c...bles.htm#Tools
If you can find a $10 version at some tool store, you're set
dude go out and buy a $5 clamp. Hell I have used channel locks, and vice grips in the past. all of these can be had in the husky section of home depot for next to nothing.
close
- Join DateJan 2007
- LocationSin City
iTrader Positive Feedback100
iTrader Feedback Score(8)
Liked:2,400 Times in 1,736 Posts
Quote:
How does that work without scratching the hell out of the outside of the caliper. Originally Posted by booey1979
Jetpilot knows of a good tool , its lite $35 and made for opposed piston calipers.
autozone rents for free (free if you return it) the tool kit to press the piston back. not sure though if it will work on a 4pot setup. here's a pic of it http://www.harborfreight.com/cpi/cta...emnumber=40732
At what point did i say I was in such financial dire straits that I couldn't afford a C-clamp... Like elementary school where we make things up as we go... ;-)
i did get a c-clamp but i am looking for a more effective tool. of course this wouldnt be needed if i was simply paying attention duh lol
close
- Join DateJan 2007
- LocationSin City
Quote:
In one minute of searching I found a $20 tool from Sears meant for 4-piston calipers.
Asterix
Looked it up, won't work. Neither will the one you posted the pic of. Does anyone actually know what a 4 piston caliper looks like, or how you compress the pistons ??? Why answer if you don't have a clue.Originally Posted by Asterix
Or, you could use a good tool that runs under $10, like the one pictured here. I've seen it at several auto parts stores.In one minute of searching I found a $20 tool from Sears meant for 4-piston calipers.
Asterix
http://www.amazon.com/Girodisc-Calip.../dp/B000XH2BYS
http://buy1.snapon.com/catalog/item....re&dir=catalog works if you keep your old pads in place
well with all of my broken bones i'm not even doing the job. but i gave up the proper technique a while ago. this way i'm looking for a primitive but effective technique which wont damage the pistons, seals, or pads.
so yes if we could get some thought provoked suggestions like terra's, i'd appreciate it guys.
or you can buy the right tool and do it right? i hate using c clamps for a 4piston or bigger caliper. honestly i bet theres a tool for under 50 that does the job effectively and properly.
yeah, i'm going to do some shopping around for the proper tool.' i was gonna do it ghetto but i'm not so big on buying replacement pistons calipers or pads lol
thanks guys
thanks guys
Well, I compressed them with the c-clamp. minimal pressure was required and it did no damage to seals or pistons. on the first caliper i failed to hold the opposite end pistons in place and when i squeezed one back in the opposite end popped out along with a surge of fluid. learned a valuable lesson. so it all needs to be bled again. just havent yet. but yeah, simple fix. assuming it all works and doesnt leak after i bleed... lol
This is what you need and works on opposed piston calipers. I have it and it works prefectly.
Piston Reset Tool
Piston Reset Tool
