Dropped on tein s techs... Toe is out of spec. Need suggestions
Old Apr 9, 2009 | 06:30 PM
freedonutss's Avatar
freedonutss
Default Dropped on tein s techs... Toe is out of spec. Need suggestions
Just dropped on tein s techs and my toe is out of spec. Steering wheel is a bit to the right even when im going straight. The question is i'm waiting for a week or 2 before I get an alignment so I can let the springs settle fully. Is daily driving with bad toe going to affect anything? btw I drive 7 days a week about 80 miles a day. Heres a cellphone pic.
Edit: Went to get an alignment and here is the before and after. BUT on the way home Toe came back out of spec. I have no clue what happened. I didnt hit any large pot holes that I remember. The steering wheel is to the right again even if im going straight. and yes I do have 35" wheels on my car
Attached Thumbnails Dropped on tein s techs... Toe is out of spec. Need suggestions-0409092012.jpg   Dropped on tein s techs... Toe is out of spec. Need suggestions-350zalignment-001.jpg
Old Apr 9, 2009 | 06:40 PM
terrasmak's Avatar
It just tears your tires up , no big deal . Just get it aligned, then after a month get it aligned again. Some places has alignment warrenties.
Old Apr 9, 2009 | 06:41 PM
got556's Avatar
got556
That's weird. I used to be on S-Techs and those are a very very mild drop. I'd tell ya to get toe bolts for the rear but I'm really not sure how your steering alignment is so far off, or why it's off at all.
Hmmm....I'd take it to a dealer and get a loaner for the time being. If your toe is indeed off....it's gonna eat tires like crazy. Toe eats tires ten times quicker than camber and your car is gonna handle really funny.
Old Apr 9, 2009 | 06:53 PM
freedonutss
I think I will go in for an alignment soon. If it makes any difference im running 20x9.5 fronts and 20x10.5 rears. 245/35/20 fronts and 275/30/20 rears. 25MM spacers all around. Should I put my stock 17s back on for now?
Old Apr 9, 2009 | 06:56 PM
Jay'Z's Avatar
Jay'Z
Spacers kill u..... Run stock see what happens.
Old Apr 9, 2009 | 06:57 PM
freedonutss
no spacers = fugly
Old Apr 9, 2009 | 06:58 PM
Jay'Z's Avatar
Jay'Z
Better offsets = safe
Old Apr 10, 2009 | 04:31 AM
dennisafrompa's Avatar
dennisafrompa
Default Align, align, align..
Anytime you change ride height, you must align...I'm guessing you did not, right.
My '08 has tein s springs installed and after re-alignment it's just fine.
Attached Thumbnails Dropped on tein s techs... Toe is out of spec. Need suggestions-100_3653.jpg
Old Apr 10, 2009 | 08:30 AM
tollboothwilley's Avatar
tollboothwilley
I've heard the S-tech drop almost 1.5" F & R...after settling.
They say they only drop .7 & .6.
Old Apr 10, 2009 | 08:38 AM
350 Rookie's Avatar
350 Rookie
Toe is the fastest tire killer. Its like takin sandpaper to wood constantly, Sandpaper being the road and wood being your tire.
Old Apr 10, 2009 | 08:59 AM
zettahertz's Avatar
zettahertz
It's probably because of loosening the spring bucket, and if he loosened the toebolt and moved the spring bucket and tightened it back slightly off, the toe will be off between the left and the right.
Mine was really screwed up after a coilover installation, just made it as straight as I can visually by adding more negative camber before alignment. rather have camber than a massive toe in. It was pretty scary driving w/ the messed up toe setting
Old Apr 10, 2009 | 09:13 AM
freedonutss
Yes I agree its handling very weird. I installed the rears myself and had a 350z shop install my fronts so I have no clue what they did. I want to wait till the springs settle before alignment but it seems like I should go in right now.
Old Apr 10, 2009 | 02:09 PM
datboijon's Avatar
datboijon
i think it would be more cost effective to pay for alignment twice then a new set of tires for ur dubz
Old Apr 10, 2009 | 05:49 PM
freedonutss
Update up top!
Old Apr 11, 2009 | 02:06 PM
freedonutss
Toe went out again. There has to be something wrong.... Anyone have a DIY on how to adjust it yourself then take it to an alignment shop to make sure its in spec?
Old Apr 11, 2009 | 02:26 PM
TheOtherRob's Avatar
TheOtherRob
Most places that do alignments around here come with a one year warranty. Why not go and get an alignment now, then come back and have it done again for free since you would be under the warranty. Ive been doing that for years...
Old Apr 11, 2009 | 02:42 PM
freedonutss
I had my alignment done yesterday. on the way home it came out of spec. went back today then on the way home again it went out of spec.
Old Apr 11, 2009 | 02:43 PM
TheOtherRob
^ Oh ok, that sounds like a pain. Best to take it back to the shop that did the springs and ask them to look over the install again.
Old Apr 11, 2009 | 05:44 PM
jubes's Avatar
jubes
after I had my springs installed, I waited about 50-100 miles... but the springs were used when I got them... and after one alignment I was fine until I got camber arms installed again, then I had another alignment done.. since then, I've been fine. I would suggest looking for members who have 20's and see if it throws off their toe alignment having a wheel that large. I know one member who had 20's and he had a -4 camber...
Old Apr 11, 2009 | 05:53 PM
Volk350's Avatar
Volk350
i have no clue!!
but i am definently in this one to find out what is going wrong, my truck is doing the same thing but its lifted, but the Z is on coilovers and has been fine....good luck
