Alignment Spec
Old Apr 15, 2009 | 09:02 AM
Spliff91's Avatar
Spliff91
Default Alignment Spec
Tried to search and visit BC website no results.
Installed the BC Suspension kit two nights ago went very well, was wondering if there is a Alignment Spec?
Im lowered 26 1/2" from ground to fender in the rear and 26" in the front. All Damenings are set at Neutral, also have rear camber kit installed.
Thanks
Old Apr 15, 2009 | 09:13 AM
zettahertz's Avatar
zettahertz
not surprised that BC didn't provide the alignment specs. It's usually given by Nissan and the alignment places should know the correct range for the toe and camber. So, unless you want to customize it for track or something, it'll be fine by just letting the alignment place do the work and set it and ask for minimum tire wear or best handling within the stock specs.
here (found on google):
Left Front
Min Nominal Max
Camber -1.33 -0.58 -0.80
Caster 7.42 8.17 8.20
Toe 0.00 0.02 0.02
Right Front
Min Nominal Max
Camber -1.33 -0.58 0.17
Caster 7.42 8.17 8.92
Toe 0.00 0.02 0.04
Total Front
Min Nominal Max
Cros Camber -0.75 0.00 0.75
Cross Caster -0.75 0.00 0.75
Total Toe 0.00 0.04 0.08
Set Back
Left Rear
Min Nominal Max
Camber -2.08 -1.58 -1.08
Toe 0.02 0.04 0.05
Right Rear
Min Nominal Max
Toe 0.02 0.04 0.05
Total Rear
Min Nominal Max
Total Toe 0.4 0.8 0.11
Old Apr 15, 2009 | 09:39 AM
Spliff91's Avatar
Spliff91
Thanks zettahertz!
Forgot to Mention have 19/245/35 +22 offset in the front and 19/275/35 +23 offset in the back. still ok?
any other suggestions.
Old Apr 15, 2009 | 09:51 AM
zettahertz's Avatar
zettahertz
I don't think wheel sizes matter.
Old Apr 15, 2009 | 04:27 PM
terrasmak's Avatar
It doesn't
Old Apr 16, 2009 | 12:03 PM
Spliff91's Avatar
Spliff91
getting my car aligned tommorow going to use stock spec unless any other opinions
Old Apr 17, 2009 | 04:08 AM
harvey a's Avatar
harvey a
Thanks for the alignment specs: question: R front camber max 0.17, L front max, camber -0.80? Please confirm.
harvey a
Old Apr 17, 2009 | 10:13 AM
zettahertz's Avatar
zettahertz
I think those are the specs given after the TSB for tire feathering. Are you thinking of running them at the max camber?
But from my last alignment sheet it shows -1.3º to .2º for both front.
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
