Front Camber Kit Needed?
Old May 11, 2009 | 07:44 AM
Yawick's Avatar
Yawick
Default Front Camber Kit Needed?
Planning on lowering by around 2" with coilovers for front and the back and was wondering if I'll need a front camber kit also along with the rear camber kit.
I don't take the car to the track or anything so I'm guessing any brand is fine right? I'm planning on getting the Eibach ones.
Thanks!
Old May 11, 2009 | 11:11 AM
terrasmak's Avatar
yes you will need front and rear kits for that much of a drop
Old May 11, 2009 | 11:45 AM
fart_canon's Avatar
fart_canon
welcome and please use the "search" fuction. Others in this board won't like you and you won't like the things they will say to you.
Old May 11, 2009 | 03:47 PM
bimmertech's Avatar
bimmertech
you will need the rear kit--camber and toe.
you do not need a front kit unless you want to return your alinment to shitty stock specs. you should have around -2 camber in the front with that drop(slightly more negative). if you use right at zero toe you should not have irregular tire wear--at least in my experiences. camber doesn't usually become a real wear factor until you get past -2.5 degrees--generally speaking.
match the rear camber to the front, rear toe to suit and have fun.
you will need a front kit however if you are off from side to side by a good amount.
Old May 18, 2009 | 11:02 AM
ZGone's Avatar
ZGone
The front will most likely need some adjustment with that much drop. If you do get a front kit be aware that upper arms are not all alike. Read the specs on the kit you are looking at because most will only add neg camber and very little if any pos to correct for lowering. Also if you get rear camber arms also add the adjustable toe arms and replace the stock toe bolt with the SPC bolt to give you greater correction of the rear toe. When you correct the rear camber it pushes the toe out. Because of the geometry of the rear radius arm mounting location, it doesn't adjust the toe very well.
Old May 19, 2009 | 04:49 PM
thinking's Avatar
thinking
By these SPL front & rear camber arms (in you want the good stuff for less $$$).
https://my350z.com/forum/competition...-of-the-z.html
Old May 23, 2009 | 07:17 AM
Eddie K.'s Avatar
Eddie K.
Yes SPL ^^^
Old May 23, 2009 | 08:25 AM
pony_killer's Avatar
pony_killer
Arada ninda apa
SPC front & rear kit installed on my 2006 with 1.25 drop all the way around...no need for the toe bolts, got my factory toe in spec.
bcoffee20
Nov 19, 2015 06:39 PM
emooheo
Oct 14, 2015 08:58 AM
codek
Sep 27, 2015 03:21 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
