Nismo S-tune Vs. Bc Racing coilovers
Old May 27, 2009 | 04:12 PM
Toñinz's Avatar
Toñinz
Default Nismo S-tune Vs. Bc Racing coilovers
Hi guys,
my question is, what is better?
Now have Bc Racing coilovers in my car, and I want to change Nismo S-tune suspension kit.
Thanks.
Toñin.
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
better is a relative term
better for?
Old May 27, 2009 | 04:37 PM
Toñinz's Avatar
Toñinz
better for?
Hi Adam,
I have bc racing suspensions, but I can't regulate them profit to extract them, Nismo have an easy installation. I have thinking of mounting nismo that already comes quite regulated
Old May 27, 2009 | 04:50 PM
Z1 Performance
Former Sponsor
I'm not following what you mean
Old May 27, 2009 | 05:07 PM
Toñinz's Avatar
Toñinz
I have bc racing suspensions, but I can't regulate them profit to extract them, Nismo have an easy installation. I have thinking of mounting nismo that already comes quite regulated.
do you have a instruction manual of Bc Racing, were to come with mesures as the tein?
Old May 27, 2009 | 06:06 PM
GeauxLadyZ's Avatar
GeauxLadyZ
Sell the BC, throw on Nismo, hire a translator.
Old May 27, 2009 | 06:08 PM
Z1 Performance
Former Sponsor
Originally Posted by GeauxLadyZ
Sell the BC, throw on Nismo, enroll in community college.
Old May 27, 2009 | 06:11 PM
GeauxLadyZ's Avatar
GeauxLadyZ
i know, saw it, corrected myself quickly.
lol, lucky you were there to put my mistaken comment in the freezer for him...
Old May 28, 2009 | 02:36 AM
Z04's Avatar
Z04
seems he is using one of those online translation programs that translates everything literally. seems he is asking if the nismo s-tune is better than the BC coilovers as far as install.
Old May 28, 2009 | 03:57 AM
alex84's Avatar
alex84
Hi!!
I´m a friend of Toñinz, yesterday I was testing his car with the BC Racing Suspension.
He has a problem. He isn´t able to regulate them correctly. Not the front axle, that works well, is the rear.
So bumpy even in the hardest positions. We have a problem in Spain ( write in foreing languages is also another problem ) because nobody has knowledge about the 350z, and there aren´t any proffesional able to regulate his suspension.
Considering this, I think that Nismo suspension is a good choice in this case. No regulations, but they have predetermined adjustment made specifically for our car.
And I know him, and which he is lokking for a good suspension but anything too stiff or radical.
Sorry for my english.
Thanks
Alex
Old May 28, 2009 | 04:03 AM
TheOtherRob's Avatar
TheOtherRob
So you are saying that even after adjusting the dampening all the way to stiff, the car is still too soft? And to correct this you want to buy an entire new suspension that is preset and basically non adjustable?
Have you contacted BC?
Old May 28, 2009 | 04:37 AM
Z1 Performance
Former Sponsor
Originally Posted by alex84
Hi!!
Thanks
Alex
Alex - post a picture of the rear spring/damper installation (from under car, car on lift) so we can see where you have preload etc. Also, what settings are you using for the rear damper adjustment? How many clicks from full stiff?
Old May 28, 2009 | 05:49 AM
Z04's Avatar
Z04
actually i think he meant it the other way around, that the harder setting is too stiff and bumpy due to the poor quality of the roads there. full hard setting will jar your teeth out on a bumpy road
Old May 28, 2009 | 07:15 AM
alex84's Avatar
alex84
I´m saying Toñin´s words, not mines. Yesterday I drove the car in straights and only a few corners. But the car lacks a lot of traction (275/35 19), that makes me think about an extremaly hard regulation. It would be better regulating the dampening more to the softer side. And these hardness probably causes that bumpy handling.
If 1 is the softnest and 32 the hardest, now is set at 27. I think...he has to do the picture
Thanks
Alex
Old May 28, 2009 | 07:31 AM
GeauxLadyZ's Avatar
GeauxLadyZ
Thanks
Alex
Is he more worried about the ride quality being too stiff or the loss of traction he is getting?
If your roads there are poor, i would recommend adjusting too a much softer setting.
The above comment made is correct, though, what you have now is adjustable... and i dont think the nismo is ( too any great degree anyway) so you should stay with BC if the roads there are bad.
Old May 28, 2009 | 09:13 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Hola tio. Si el problema que tiene es que le salta mucho el coche en los baches, es porque tiene el amortiguador ajustado demasiado duro. Dile que lo ponga casi a los mas blando possible y vera que mejorara un huevo en la calle.
Old May 28, 2009 | 09:40 AM
warmmilk's Avatar
warmmilk
^ what he said
Old May 28, 2009 | 09:52 AM
jubes's Avatar
jubes
awesome... this is like watching Telemundo.. and those Novelas..
Damn those chicks are hot on those shows LOL
Old May 28, 2009 | 10:12 AM
TRYNALIVEPRO's Avatar
TRYNALIVEPRO
Originally Posted by jubes
damn those chicks are hot on those shows lol
+100000000000000000000000000000000000000000
Old May 28, 2009 | 10:23 AM
CarlosCh's Avatar
CarlosCh
Esto es correcto... la pérdida de tracción se debe a que estás dejando la suspensión extremadamente firme, lo cual sólo funciona en una pista de carreras. En carretera normal, es mejor que ande entre suave y medio.
Lo que pueden hacer es tratar con la suspensión desde el setting más suave posible y probar hasta alcanzar el resultado que necesitan.
No hace falta que se pase a la Nismo-S, con esos BC probablemente puedas llegar a lo que necesitas para andar el auto a diario.
Suerte!
