5 hours labor for a spring install?
Old Jun 19, 2009 | 11:36 AM
Lawn Dart's Avatar
Lawn Dart
I'd say 3 or 4 hours is more likely. However, if we're not experienced with the 350z, five hours doesn't sound completely unreasonable. Yes, the rear springs can be swapped in quickly. However, the fronts can give you problems. Also, the fronts require you to disassemble and reassemble each unit.
Shops aren't out there to set world records.
Old Jun 19, 2009 | 11:42 AM
Entaille's Avatar
Entaille
Originally Posted by bimmertech
you guys are missing the point here. when taking stuff to a shop, it doesn't matter how fast you can get it done--it matters what the book time is.
i can assure you the guy doing the install can do it just as fast(or faster) than most on here, but that makes no difference in the price at all.
maybe you are missing the point .. if I take my car for a simple job and already know what it entails, and how long it should take with proper tools/education, I expect the shop to be as close to that point in labor as possible. if they need to book extra time 'just in case' that's their own damn fault and I'd go elsewhere :P
Old Jun 19, 2009 | 11:43 AM
SirSpeedyZ's Avatar
SirSpeedyZ
go somewhere else or do it yourself
Old Jun 19, 2009 | 12:29 PM
BigD2k5's Avatar
BigD2k5
mitchell online labor guide shows 2.6 for both front and 2.1 for both rear and that does not include alignment. that's a little high so i'm sure you can always find a regular suspension place to charge a little less. then take to nissan dealer for the 59 or 69 dollar alignment. maybe more if they need additional hardware though.
Old Jun 19, 2009 | 01:12 PM
bimmertech's Avatar
bimmertech
the book time is there for a reason and if you find a shop that will sell the job for how much the customer thinks it should take then just stick with them.
how successful in the past have you been in negotiating a labor time?
There is no way on god's green earth the book time for springs is 5 hours...there is NO WAY.
apparently according to mitchell its 4.7
if you guys don't like paying BOOK labor times for mods then learn to do it yourself or find a guy that does side jobs.
Old Jun 19, 2009 | 01:54 PM
GeauxLadyZ's Avatar
GeauxLadyZ
I didnt do it myself nor did i find a guy who does "side jobs". i went to a tuner shop and paid $100. Done. Worth every penny.
So unless he charges $20/hour labor rate, i seriously doubt most shops would go by a 5 hour book rate....but ok Mitchell says its so, so it must be so...
The highest ive ever been quoted on spring install is 175.00...btw. So ya.
Old Jun 19, 2009 | 02:34 PM
Lawn Dart's Avatar
Lawn Dart
Most people expect a spring install to be cheaper. However, it's more work than a coilover install.
Old Jun 19, 2009 | 06:56 PM
MyZ4U2C's Avatar
MyZ4U2C
Midas said today they would do it and the guy said 2 hours.
Old Jun 20, 2009 | 08:24 AM
TYEster's Avatar
TYEster
Link to the DIY thread?
Springs/camber kit are coming in Monday and it's up for debate on doing myself or taking it somewhere.
Old Jun 20, 2009 | 07:06 PM
beezee's Avatar
beezee
$100? Was the owner of that shop facing foreclosure?
Old Jun 20, 2009 | 07:09 PM
2pink1stink's Avatar
2pink1stink
I just installed my springs and camber kit today. started at 10:30 got done around 5:00. With the help of a friend. My knees are killing me lol. Not that bad of a job really. My car is walking all over the road and I have a popping noise on the drivers side front when I turn the wheels or hit a bump. I think I didn't tighten the top nut on the strut enough. I'll tear it down tomorrow and try again, then off to the alignment shop Monday. You should do it yourself and save a few hundred for some more mods
Old Jun 20, 2009 | 07:42 PM
beezee's Avatar
beezee
Good job. Tear it down tomorrow, try again and add up the total time and let us know. That would help
Old Jun 21, 2009 | 01:05 AM
b00b00's Avatar
b00b00
I got mine knocked out in about 3-4 hours. A member on here helped me (matavis) Dod it in his garage.
Then again we had a impact to compress the springs.
Old Jun 21, 2009 | 03:57 AM
bimmertech's Avatar
bimmertech
looks like he's from houston, in which case it was prolly some beaner shop that didn't even charge taxes
Old Jun 21, 2009 | 05:29 PM
TYEster's Avatar
TYEster
**nm**
Old Jun 21, 2009 | 06:08 PM
b00b00's Avatar
b00b00
Don't hate on beaners, if it wasent for them I would have never got my 08 wheels with NEW potenza re50s all around for $380
Old Jun 22, 2009 | 06:58 AM
GeauxLadyZ's Avatar
GeauxLadyZ
No man, it was a rep. tuner shop here in Houston...others in Htown on this forum have used them as well. Its a young guy that loves working on imports (specializes in 350z/G35) and charges rates how they SHOULD be. A spring install is by no means hard, AT ALL, for a shop with a lift and compressor. not a beaner shop by any means.. just a small shop trying to bring in more business.
If your not retarded its not hard to find a shop that will do it cheap, usually small shops will to try and give you great price so you come back...thats it.
so shop around and call other shops.
Old Jun 24, 2009 | 05:12 PM
  #38
smaha's Avatar
smaha
I've been calling around all over the Spring (N.Houston) area. Been quoted prices between $220 - 520 for installing Eibach Pro Kit. + alignment charge.
Old Jun 25, 2009 | 09:22 AM
  #39
GeauxLadyZ's Avatar
GeauxLadyZ
Ya, i havent gotten alignment yet, cause your supposed to wait for springs to settle before you get it aligned. So it was just 100 for install. Alignment should only be no more than 100, so either way FYI.
Also, your only looking in Spring, there is your prob. I live on West side not too far from downtown. If you want good prices and more shops to chose from your gonna have to get outside spring and look around closer to downtown. 220 is a great price if they include alignment, go with that.
Old Jun 25, 2009 | 10:39 AM
  #40
350 Rookie's Avatar
350 Rookie
Drive to CT. 120 for spring installs and less than 2 hours.
