Creaking in the suspension?
Old Jun 16, 2009 | 05:39 AM
Izzysparks3's Avatar
Izzysparks3
Default Creaking in the suspension?
I just bought an 06 Base model 350z in April, and now I am hearing a creaking noise in the front end only when I am driving slow. It only happens when I'm slowing down or turning, I'm not sure what it is or weather it will be covered under warranty, any honest opinions would be great considering I do not know a lot about this kind of stuff ... thx
Old Jun 16, 2009 | 05:48 AM
Rattles, creaks and squeaks are difficult to diagnose and fix. The car should be on a lift, with someone in the car bouncing up and down (literally).
WD-40 is great but does not fix anything. Creeks from components like shocks indicate that they are failing. Good luck.
Old Jun 16, 2009 | 05:54 AM
TJGILROY's Avatar
TJGILROY
sounds like the regular noises from a z...
Old Jun 16, 2009 | 06:49 AM
King350Z's Avatar
King350Z
Yeah no freakin kidding lol
Old Jun 16, 2009 | 06:56 AM
rockinbboy's Avatar
rockinbboy
squeaks aren't regular sounds. The Z can be a bit noisy, but I haven't heard squeaks on my 06... (knock on wood) I'd get it checked out to be safe.
Old Jun 16, 2009 | 07:06 AM
JasonZ-YA's Avatar
JasonZ-YA
I would use a teflon based lubricate.......but first off i would get the Z in the air and check/inspect for any binding or indications of wear, metal on metal spots. shinny sports or spots where oil junk is smeared and see if there is a cause for the noises you hear...
-J
Old Jun 16, 2009 | 07:11 AM
firekrave's Avatar
firekrave
Dude, take a look at your compression rods. I have had that noise (or a noise similar) twice and both times it was compression rods. They may not need repairing, just readjusting and re-torquing.
Old Jun 16, 2009 | 07:32 AM
TJGILROY's Avatar
TJGILROY
you read wrong, he said creaks, i've had them since i've owned mine...
Old Jun 16, 2009 | 07:45 AM
firekrave's Avatar
firekrave
Funny how you have to be specific with the noise from the Z. lol
Which one of these means something is wrong with your Z: a)rattles b)squeeks c)creaks d)hum e)vibration at certain speeds f)quiet ride
Old Jun 16, 2009 | 08:30 AM
zakmartin's Avatar
zakmartin
My '08 started creaking from the front about 2 weeks ago. It sounds like an old pickup truck when I'm driving on anything other than fresh pavement. I'm taking it in for service next week. It shouldn't sound like this after only 2400 miles.
Old Jun 16, 2009 | 08:55 AM
tylerxfire's Avatar
tylerxfire
Old Jun 16, 2009 | 09:07 AM
TJGILROY's Avatar
TJGILROY
if you don't have a sports car worth over 60k$ you'll rarely see option f...
Old Jun 16, 2009 | 09:47 AM
firekrave's Avatar
firekrave
True story
Old Jun 16, 2009 | 04:18 PM
Izzysparks3
Thanks for the imput guys.
Old Jun 17, 2009 | 03:40 PM
egz's Avatar
egz
i know what ur talking about... i get it to most often when i start going from a stand still or if i was just backing up and now goin forward the shift in loads makes a creeking noise im guessing ive been meaning to get it looked at... btw its an 03 with 30k miles
Old Jun 17, 2009 | 08:21 PM
Peak350's Avatar
Peak350
Try retightening the A-arm bolts.
Old Jun 17, 2009 | 08:35 PM
freedonutss's Avatar
freedonutss
Locate your endlinks on the front and rear of your car. If the ball joint on the endlinks do not rotate easily and feel like they are stuck or "binding" its time for some new endlinks. They are inexpensive and found them for about $20 a piece. Im about to replace my fronts because they are completely binded in the front and cause major clunks and creaks while driving slow and hitting bumps.
Old Jun 17, 2009 | 08:49 PM
guitman32's Avatar
guitman32
+1. Endlinks are a common culprit for creaking/clunking.
Old Jun 17, 2009 | 09:31 PM
egz's Avatar
egz
^ thanks for da advice will check that!
Old Jul 30, 2009 | 04:36 PM
Izzysparks3
Just a couple of loose bushings, cost me nothing!
