lowering on coilover or springs
Old Jul 3, 2009 | 07:05 PM
vqpowered's Avatar
vqpowered
Default lowering on coilover or springs
im about to buy a Z soon whats the best way to lower the car? just so it has a big of a tuck or no wheel gap....im guessing i would go wit coils but not sure...and would i also need a front and rear camber kit or would they Z have ajustable ones? cuz on my 08 si i had to get camber arms if i went over a lowering point and whats the best bang for the buck coils and best bang for the buck springs.....also off topic if im debagdeing the nissan emblems will iu have holes?
Old Jul 3, 2009 | 07:16 PM
NightShade's Avatar
NightShade
I would think best bang for buck is always coilovers. With springs you have an idea of what the drop would be, but you're stuck with it afterwards. With coilovers at least you have some options about height/ride comfort. For example if you're just driving in the city keep it at one height and then when you take it to the track lower it for that day.
If it were me and I had the money, I'd get coilovers.
Old Jul 3, 2009 | 07:27 PM
vqpowered's Avatar
vqpowered
thank yea im stuck between the 350z and a s2000 idk what car i wanna get so im tryna research both but as for lowering the Z do u need camber arms?
Old Jul 3, 2009 | 09:31 PM
black_03's Avatar
black_03
Not being an a$s, but do what is listed below. There are a lot of topics and posts related to that question and I am sure you will find answers to future questions.
How to use search
Using the following options are recommended to get the most accurate results from search
Advanced search - Use the Advanced Search page to gain more options on searching.
Select correct forum - If you know what forum the thread or post is, select to search only that forum/s (multiple forums can be selected by holding down "CTRL" when selecting).
Thread titles - If you know the title of the thread, select to only search thread titles.
Use quotation marks - If you feel that the words you are searching for may commonly be together, place quotation marks around them (i.e "fuel injector"
Use the users name - If you know who made the post/thread that you are searching for originally add their username to the "User Name" area
Limit the date range - If you have an idea of when the thread that you may be searching for was posted, limit the date range using the option available.
MOST IMPORTANTLY - return your results by relevancy
Old Jul 4, 2009 | 01:22 AM
1SleeperZ's Avatar
1SleeperZ
The middle "nissan" emblem on the back does have holes (2)
I learned the hard way and stuck it back on, but the "350Z" on the drivers side hatch is just stick on.
Old Jul 4, 2009 | 12:03 PM
Gsedan35's Avatar
Gsedan35
Better answer's depend on the car's oem suspension, like the S2000, Nissan made changes to the 350z over the years.
2003-2004 350Z
Tanabe GF210 1.2" drop
Cusco or SPL front camber arms
SPC rear camber arms w/elongated toe cam bolts or SPL rear camber arms w/elongated toe cam bolts
2004.5+ 350Z
Eibach Sportline 1.2" drop or H&R sport springs 1.3"/1" drop
The thing about making a coilover choice in your case vs a shock and spring choice is this. All you have mentioned is looks. If your not willing to poly up $$ for a good product choice, I don't see the point in buying what likely would be cheap coilovers. Only cheap coilover I would recommend would be the Eibach Pro-S at about $999-$1099. It's a rebaged Kw Variant 1 and offer's a 1.5" max drop, but good german engineering (think construction and valving).
Old Oct 5, 2009 | 05:47 AM
What did you get?
Old Oct 5, 2009 | 07:35 AM
Gsedan35's Avatar
Gsedan35
Originally Posted by davidv
What did you get?
Since he never returned I'd say S2000 or maybe nothing.
Old Oct 27, 2009 | 01:38 PM
True. Little difficult to lower a car that you don't have.
