Does ABS system store codes?
Old Jul 8, 2009 | 01:50 AM
Ziggyrama's Avatar
Ziggyrama
Default Does ABS system store codes?
Hey guys,
My ABS light has been coming on and off occasionally and I'd like to plan a trip to the dealership to have it looked at. It happens usually after the car has been heat soaked. I hear a buzzing sound from the ABS motor area when I turn teh car on and the ABS light stays on. If I turn the car off and let it cool, the light will eventually go away. I know that the ABS system can be scanned with consult tools for diagnostic purposes when a fault is detected (similar to ECU scan) but what I am not sure about is if the system actually stores historical codes. Anybody know this info? Ideally, I'd bring teh car in, they'd scan it and even if the light is not on, they'd be able to pull the code from ABS system and hopefully fix the problem. Any ideas?
Old Jul 8, 2009 | 09:23 AM
Very good question.
We know that OBDII stores codes related to emissions and other problems. Remember that ABS is part of the ABS TCS VDC computer. Its one computer. I do not know what the relationship is between OBDII and the ABS TCS VDC computer.
Old Jul 8, 2009 | 09:32 AM
DavesZ#3's Avatar
DavesZ#3
The ECU stores codes. If the ABS or any other system "throws" a code, then yes, it will be stored.
Old Jul 9, 2009 | 01:52 AM
Ziggyrama's Avatar
Ziggyrama
Good point. SES light does not come on but I saw my ABS light come on again yesterday. I can do an ECU scan and see if any codes are present. It would be nice if the ECU did have this info. I'll do a scan and report back.
Old Jul 10, 2009 | 10:42 AM
Laughitup85's Avatar
Laughitup85
check your break pads, I had my ABS, SLIP, and VDC lights come on and when I checked my pads they were low as **** but once I replaced them the lights went off
Old Jul 10, 2009 | 11:17 AM
DavesZ#3's Avatar
DavesZ#3
It could be that the ABS system is flaking out. Not a bad idea to check brake fluid, pads, rotors, etc. though.
Old Jul 10, 2009 | 05:51 PM
Ziggyrama's Avatar
Ziggyrama
The buzzing sounds coming from the ABS motor area suggest that the ABS system is just tired. I replaced my front and rear pads last year so that isn't it. I checked the brake fluid level the other day and it's right at the high mark. The rotors are on their way out but they still have a little life left in them. The new pads are a metallic/ceramic matrix pad so they're not brutal on the rotors but not as gentle as pure ceramics either. I think it's the ABS system. I haven't had the chance to scan the car yet. I'll swing by Autozone tomorrow AM and have them do a scan.
sales@czp
Sep 23, 2019 03:30 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
