Coilover Install DIY???
Old Jul 18, 2009 | 10:17 AM
s13_marine's Avatar
s13_marine
Default Coilover Install DIY???
Sorry if i overlooked it, searched here and DIY but couldn't find any. Looking for DIY install for coilovers. Need to install tanabe pro 5's. Thanks for your help.
Old Sep 5, 2009 | 03:37 PM
M3ANMACHINE's Avatar
M3ANMACHINE
Bump, I'm also looking for a DIY on Coilover Installation
Old Sep 5, 2009 | 04:18 PM
Asian Invasian's Avatar
Asian Invasian
Just look for the spring install, mostly the same concept. It should be easier because you dont have to worry about taking the spring off the shock.
Old Sep 5, 2009 | 05:34 PM
guitman32's Avatar
guitman32
Will be exactly the same as spring/damper install, minus setting the final ride height.
There will be other differences, such as front strut components reused (front rubber upper spring seat, strut top mount, etc), and whether it uses a true coilover config in the rear. These are minor differences though, and can be tackled without the need for a coilover specific DIY.
Old Sep 5, 2009 | 10:47 PM
blazinasian's Avatar
blazinasian
I'm sure most will say use the SEARCH function, but I'll try to be helpful since I'm in the process of installing my coils. Here are some links that I've found very helpful...
http://g35driver.com/forums/brakes-s...sterday-5.html
http://www.g35nyc.com/forums/showthread.php?t=470
Also here's a link that shows the torque specs for each bolt for both front and rear suspension...
http://g35driver.com/forums/wheels-t...tall-tips.html
These links should help put you in the right direction. Good luck!
Take care
Old Sep 6, 2009 | 08:46 AM
terrasmak's Avatar
If you need to look at a DIY thread to install them , you probably should look for competent help.
Old Sep 6, 2009 | 09:02 AM
bimmertech's Avatar
bimmertech
exactamundo.
Old Sep 6, 2009 | 09:52 AM
M3ANMACHINE
I've installed a set before, a DIY would just be to double check...
I swear people on this forum become bigger and bigger a holes by the day
Old Sep 6, 2009 | 11:56 AM
Voboy's Avatar
Voboy
imo its like a spring installation... possibly even easier.
Old Sep 6, 2009 | 12:50 PM
blazinasian
Install isn't too bad, just have a friend handy to help out. Also take your time and have some patience (or a couple of beers haha)! You'll definately get a better sense of satisfaction knowing you did it yourself than having some shop do it.
Take care
Old Sep 6, 2009 | 01:02 PM
sofa king's Avatar
sofa king
you should make a DIY thread since there isnt one.
Old Sep 6, 2009 | 02:02 PM
Rushhour's Avatar
Rushhour
Would any one Know how to install the rear Dampener extensions.
Old Sep 8, 2009 | 08:41 PM
M3ANMACHINE
They're a waste IMO. I just drilled holes in the rear strut brace last night. Worked like a charm
Old Sep 9, 2009 | 05:26 AM
INTIMAZY's Avatar
INTIMAZY
Just a few tips OP...
Some spring install threads on here claimed you needed to unbolt either the upper or lower arm from the spindle in order to get the front coilover in or out.
Just turn the wheel left or right a bit and the curved section gets out of the way very nicely
Install is very straightforward. You probably will want to disconnect the sway bar to get more travel. Otherwise, everything bolts in like factory.
Hope some of this is useful.
Old Sep 9, 2009 | 05:45 AM
350Zenophile's Avatar
350Zenophile
Agreed. This is a valid post and I'm surprised myself we don't have one. Always good to double check tools needed, get tips from others, etc.
Everyone wants to act like they are ASE certified when really they've maybe done 1 or 2 in their life.
Old Sep 9, 2009 | 04:18 PM
aloh's Avatar
aloh
its pretty basic and straightforward. All you need are the right tools and some elbow grease. Its pretty hard to mess it up unless you really dont know what you're doing. Good luck!
Old Sep 9, 2009 | 04:25 PM
terrasmak's Avatar
OK i'll do the DIY
front
1. jack car and removed wheels
2. removed stock strut bar
3. unbolt swaybar from LCA
4. pop UCA off steering knuckle
5. removed strut assembly.
6. reverse order
Rear
1. Jack/wheels
2. unbolt shock
3. unbolt spring bucket arm at kuckle, remove spring
4. reverse the order while installing the new shiny parts
Once installed, have fun setting ride height.
Old Sep 9, 2009 | 10:19 PM
M3ANMACHINE
I did it the other day and just as I assumed, it's very straight-forward!
Very basic. The hardest part is removing the front strut assembly (gotta maneuver that $hit around!!!)
Old Feb 20, 2022 | 12:04 PM
miggs's Avatar
miggs
Default coilover step by step installation
There is this 370z coilover instal video that goes step by step. It should be similar to the 350z I think. link below
video:
Old Feb 21, 2022 | 03:45 AM
travlee's Avatar
travlee
Master
video: https://www.youtube.com/watch?v=cI3f11TgilI
13 years late to the party
