Megan Racing Springs
Old Aug 20, 2009 | 08:16 AM
GT-Z's Avatar
GT-Z
Default Racing Springs
Does anyone have Racing springs on there z or know anyone with them. That will lower the car nice & not have to roll the finders. I have oem shock & struts on 18" tires 245/40/18. Will it ride okay & if u have Pic's of them Installed, will be great to. Thanks
Old Aug 20, 2009 | 10:40 AM
GeauxLadyZ's Avatar
GeauxLadyZ
Originally Posted by GT-Z
Does anyone have Megan Racing springs on there z or know anyone with them. Thay say thay lower the car 1.2" will this work without having to roll finders. I have oem shock & struts on 18" tires 245/40/18. Will it ride okay & if u have Pic's of them Installed, will be great to. Thanks
The seat guy!
Ill help out since i made a dick comment on your seat thread, but you need to learn how to search my son.
Dont buy Megan springs, there is no point. If its a 1.2 drop all around you want, i would prefer the Tanabe NF210's over anything Megan. Plus springs are all around the same price anyway, so why go cheap?
However, the Z sits a little higher in the rear than front, so getting an even drop on springs f/r will keep this stance. If you want it leveled off, i would recommend Tanabe GF-210s. (1.0f / 1.2r), which will make it alittle better.
Lastly, Once you move past a .8" - 1" drop, your pretty much asking to blow your stock shocks out within a much shorter timeframe. I would upgrade if going an inch or below, just for good measure. Your also asking for rear camber/toe problems once you move past the above mentioned height, as well.
Its different on each Z, but your pushing your luck on needing some rear camber arms/toe bolts.
Old Aug 20, 2009 | 12:23 PM
GT-Z's Avatar
GT-Z
Gotcha... Im putting TOKICO HTS Adjustable Shocks & Struts soon, so Tanabe NF210's
would set the Car off Right. I Just want to sit Low as i Can without modding Anything like body rolled, etc.
Old Aug 21, 2009 | 04:12 PM
T_K's Avatar
T_K
245/40/18 is the right size for the front. It's about an inch short overall for the rear. 245/45/18 is the proper rear sizing. Tire size and wheel offset will determine how low you can ultimately go.
TK
Stevo Z
Oct 3, 2015 09:14 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
