Help with Tein S tech springs
Old Aug 20, 2009 | 09:09 AM
surfer05rdr's Avatar
surfer05rdr
Default Help with Tein S tech springs
hey guys i recently bought some S tech tein springs. When i bought them the guy said that they were for a G. But just about every spring that i have looked at will fit a G or a Z but i have been looking around on the G forums and alot of the G guys are saying that the G S techs will not fit a Z. I was just wondering if this is true. Most springs i seen will fit Z or G they basically have the same suspension. Thanks guys
Old Aug 20, 2009 | 10:04 AM
Gsedan35's Avatar
Gsedan35
DO NOT INSTALL G35 S-techs on a 350Z
Yes they will install, you will get .5" less drop then the published G35 coupe drop, but they have rear spring rates that have no business on a 350Z.
Oem 350Z spring rates 2003-2004
314/342
Oem 350z spring rates 2004.5"
314/427
Tein S-tech G35 coupe 1.2”/.9” (fronts are progressive, rears are linear)
Spring rates in LBS 358/274 (final rates only, softer intial front progressive rate unknown)
My advice to you is to sell them on G35 driver and buy the kit ment for the Z, much MUCH superior spring rates
Tein S-tech 350Z springs .7“.6“ (fronts are slightly progressive, rears are linear)
Spring rates in LBS 386/402 (estimated front intial rate is 327lbs)
Errrr, you do have a 350Z,....correct?
Old Aug 20, 2009 | 11:53 AM
beezee's Avatar
beezee
You are lucky the first response to your question is from gsedan35. My advice to you is "take his advice and call it a day". That guy knows about the
Z and G suspension like a guru.
Old Aug 20, 2009 | 01:36 PM
surfer05rdr
314/342
314/427
hey yes i do have a 350z lol but thanks for the advice i will prolly try to sell them on g35driver. Im glad i asked this question before i spent the time to install them. Thanks. Is there any springs that you would really recommend that have about a inch drop
Old Aug 20, 2009 | 10:48 PM
Gsedan35's Avatar
Gsedan35
Yes, though I don't know anything about what you want out of the suspension other then the drop.
Eibach 350Z Pro-Kit progressive springs 1”/1”
Spring rates in LBS initial/final front 296/384 initial/final rear 316/421
EnjukuRacing
Sep 30, 2015 06:55 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
