Suspension problem. Help!
Hey
So recently I curbed my wheels real bad, bad enough to throw off my alignment by a lot. So I got an alignment done, and prior to the alignment my passenger side was sitting higher then the driver side(after curbing my wheels). So I can't find out what's wrong with suspension. I'm lowered on Tanabe NF210's. My driver side camber was, still kind of is messed up. Front is set at -1.5, and rear is set at -2.5ish, and passenger side camber is almost close to stock setup, but the Toe on the passenger side is completely messed up, I don't know the specs, but I can get them if it'll help solve my problem. Oh, and it's the rear passenger side that's sitting a little higher then my driver side. If you look at my car from the rear, you can kind of tell it's leaning. Somebody help!! Thanks!
hm.. sorry to hear about that man. i did the same thing earlier this year, but i actually broke my front shock. litterally bent. i ended up just going for a new set up. hopefully you wont have to do that though.
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
