coilovers or springs
I have a couple questions. First off my limit is to spend around 50 tops i mean if something 550 i pay if it worth it. Second this is with springs i know once you get that height you cant change them from what i heard. I want to know what springs you guys have or if you suggest coilover springs
Thanks Mike
Thanks Mike
Same here. I recommend saving up some more and getting coilovers instead of wasting your money on springs that will just kill your shocks down the line. And you might not even be satisfied with the drop you get with springs.
550 wont' get you far on springs as well (assuming you buy new). You'll need camber arms if your drop is 1" or more. Save some more money junior.
As for springs and or coilover suggestions. Try using the search button.
springs you can only adjust center of gravity once, usually an inch, and thats it. coilovers allow you to adjust ride height in from and rear during installation giving you a more distinct look and higher ride quality.
save for coils..im in that line as well..
I bought springs first. . .
Coilovers are being installed today
If you are only going for the look - springs are cheaper
if you want performance and adjustablity then go with coilovers
As for which ones - lots to choose from - depends on how much you wanna spend
I got Tanabe Pro Fives along with the TEAS controller. . .
I have a roadster and you cant manually adjust the rears without taking them out - so I went with the electronicly controlled ones. . .
