Stock vs. Track brakes... same master/slave cyls?
Old Oct 13, 2003 | 09:56 AM
azrael's Avatar
azrael
Default Stock vs. Track brakes... same master/slave cyls?
Do the stock and track (brembo) brake systems share a master and slave cylinder configuration? If I find some Brembo rotors/calipers from a wrecked track model car, can I just swap them directly, or am I going to have to purchase the rest of the brake system as well? I know these answers can be found in the service manual, but I don't have one quite yet..
Old Oct 13, 2003 | 10:54 AM
jtree007's Avatar
jtree007
Charter Member #53
For the most part it is a direct swap.. make sure you get the bolts from the car with the brembos or new ones as they are longer... you will have to replace or remoe the dust shield behind the rotors b/c the track rotors will hit them
Old Oct 14, 2003 | 09:48 AM
peptidbond's Avatar
peptidbond
Brakes lines are different too. However, you may be able to reuse the stock lines. Not sure.
Old Oct 14, 2003 | 11:18 AM
azrael's Avatar
azrael
hm, thanks for the info, guys. Chances are, I'll get some stainless steel brake lines at the same time, so hopefully that won't be a problem.
sales@czp
Sep 23, 2019 03:30 PM
