Possible to use rear OEM upper mount with Tein Flex?
Old Oct 21, 2009 | 07:13 AM
JEFFOS69's Avatar
JEFFOS69
Default Possible to use rear OEM upper mount with Tein Flex?
Just installed some Tein flex's on my Z and they are a bit noisy (as expected and as most tein owners notice) It is related to the rear pillowball mounts.
I want to know if its possible to remove the upper mounts on the rear and swap them out for the OEM rubber ones?
Trying to figure out if this is possible before I take the rear suspension out.
Thanks
-Jeff
Old Nov 18, 2009 | 12:45 PM
JEFFOS69's Avatar
JEFFOS69
I'll bump this once hoping somebody knows.
Up you go.
Old Nov 18, 2009 | 07:23 PM
bimmertech's Avatar
bimmertech
i can't comment on the teins, but i have done it with two other sets of coilovers.
one required a step bit and a cutoff wheel, the other pretty much bolted right on.
i don't recommend this as a permanant solution though. i did it as a temp while i removed the bearings and filled the mounts with urethane and a sleeve type bushing--like the oe rubber uses. this was a last resort as i could not find anyone locally that could find me the odd ball metric spherical bearings the pillow mounts used.
Old Nov 20, 2009 | 06:13 AM
JEFFOS69's Avatar
JEFFOS69
Thanks for the reply!
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
nanotech
Oct 2, 2015 05:02 AM
samansharif
Sep 25, 2015 12:31 PM
