Tire feathering need help!! I have PICS.
Old Nov 24, 2009 | 12:51 PM
Nismokingz33's Avatar
Nismokingz33
Default Tire feathering need help!! I have PICS.
Hello I need help...can someone tell me how to stop the tire feathering The car has 100k miles and I just bought nismo s-tune suspension for the front and the rear I also got sway bars. My question is will the feathering stop once I install the new nismo S-tune suspension? Thank you
Old Nov 24, 2009 | 01:15 PM
StevieZ's Avatar
StevieZ
NO - install the Nismo set up then get alignment done
Old Nov 24, 2009 | 01:19 PM
That is pretty serious. I installed the nismo S-tune suspension about 2,000 miles ago. Probability that it will "fix" feathering is about 20 percent.
Q: Why did you NOT swap tires 10,000 miles ago?
Old Nov 24, 2009 | 01:27 PM
chrisjersey06's Avatar
chrisjersey06
Get some adjustable camber arms. Nissan's "tire feathering" issue is really just negetive camber set in to promote better handling. If you don't need the extra little bit of handling, or are just going to drive the car on the street, then get some adjustable arms and dial the camber back in.
Old Nov 24, 2009 | 01:36 PM
DavesZ#3's Avatar
DavesZ#3
How often have you/previous owner had the car aligned?
Old Nov 24, 2009 | 01:59 PM
Nismokingz33
Q: Why did you not swap tires 10,000 miles ago?
You mean rotate? The tires are about 8 months old.
Old Nov 24, 2009 | 02:03 PM
DavesZ#3's Avatar
DavesZ#3
You can't rotate on the Z. You can swap them from side to side, the old inside edge becomes the outside edge and vice-versa. That doubles the life and evens out the wear.
How about alignments?
Old Nov 24, 2009 | 02:05 PM
Nismokingz33
I got the car aligned about a year ago.
Old Nov 24, 2009 | 02:11 PM
The tires are directional so a regular rotation will not work. A swap will put the inside on the outside and outside on inside.
Hint: Estimate life of tire. Swap at half that.
Old Nov 24, 2009 | 03:06 PM
DavesZ#3's Avatar
DavesZ#3
Depending on your road quality and how you drive, that may not be often enough. The shop doing the alignment may not have calibrated their machine leaving you with improper toe setting. That's the cause of the feathering.
Old Nov 24, 2009 | 03:30 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
I am probably wrong, but this doesn't look like feathering. It looks like cupping to me.
http://www.procarcare.com/includes/c...dtirewear.html
Old Nov 24, 2009 | 03:58 PM
DavesZ#3's Avatar
DavesZ#3
It's hard to tell from pictures anyway - not enough detail, shadows, dirt, lighting... You can really tell by feel more than appearance.
Old Nov 24, 2009 | 04:22 PM
We generally refer to the high-low block pattern as feathering. The high block has a distinctive high ridge that can be easily felt and seen from the side. Looks like a saw tooth from the side. Feathering or cupping it is typical 350Z wear.
Old Nov 24, 2009 | 05:07 PM
Nismokingz33
Wow!!! Thank you for the link it really helps explain what the problem might be. A lot of info. Thanks.
Old Nov 24, 2009 | 07:03 PM
terrasmak's Avatar
not really
Old Nov 24, 2009 | 07:30 PM
TreeFiddyZee
Do WHAAAAT!?
You sir, are a descriptive machine!
Thanks.
Old Nov 25, 2009 | 07:08 AM
chrisjersey06
not really
Have anything else to add to that? My tires are "feathered" because of my camber settings, I'm sure if I dialed them back in that they would wear evenly.
Old Nov 25, 2009 | 07:53 AM
DavesZ#3's Avatar
DavesZ#3
Feathering is caused by toe setting, not camber. Negative camber wears the inner edge smooth.
Old Nov 25, 2009 | 04:24 PM
bimmertech's Avatar
bimmertech
exactly.
you can run a lot of negative camber before you will even begin to realize uneven tire wear. i have run upwards of -3 with no adverse effects on tire wear.
i always keep my front toe at 0.
fwiw tire feathering can also be a function of the tire used. some tires have softer outer/inner tread blocks and simply cannot cope with the amount of toe in todays performance cars use. take for instance goodyear eagle all seasons, those things will cup/feather/whatever on damn near anything.
Old Nov 25, 2009 | 04:26 PM
cdoxp800's Avatar
cdoxp800
You beat me to it
