parking brake problem
Old Dec 8, 2009 | 10:09 PM
lemmiwinkz's Avatar
lemmiwinkz
Default parking brake problem
i just got an 03 z about 6 months ago and noticed that its parking break was a little loose. the guy i got it from i would guess was almost 50 so i dont think he was doing anything crazy with it, i think it was just a little loose. anyways i looked on forums and found some guides to tighten it up by pulling the little ashtray/coin holder thing out and tightening the bolt up. i only turned it a couple times and it worked perfectly. i was in my relatively flat driveway and took it out of gear, with the parking break off, and was able to just push the car very easily with my foot from out the door. at that point i did not think i tightened it up to much and called it good. however i just noticed yesterday that when i hit the breaks pretty hard that the red "brake" light (the one that lights up when your parking brake is on) came on until i released the break again. i did it on purpose a couple more times and i did it consistently every time. did this come on because i tightened that little bolt a little to much or is it something completely different? any help would be awesome.
lemmi
Old Dec 9, 2009 | 11:12 AM
lemmiwinkz's Avatar
lemmiwinkz
please someone help
Old Dec 9, 2009 | 07:54 PM
KORRUPT's Avatar
KORRUPT
I just finished doing the brakes on my g35 last week. I replaced the rotors and pads and at the same time tightened the emergency brake. I believe the best way to tighten them is from the service manual which requires that you remove the rear wheels and make the adjustment to the parking brake shoes first, then finish by adjusting the brake handle. I did mine this way and they work terrific without any issues at all. The link to the adjustment is:
http://www.g35frenzy.com/downloads/2...anual/F/pb.pdf
go down to page pb3 and follow directions.
Hope this works for you.
K
Old Dec 10, 2009 | 11:01 AM
Thermal1's Avatar
Thermal1
It might be something completely different. Check your brake fluid. It might be low.
Old Dec 10, 2009 | 10:01 PM
lemmiwinkz's Avatar
lemmiwinkz
cool thanks guys, ill check the fluid tomorrow and if thats not it ill go in and tighten the parking break that way (as soon as all this snow melts, i have not got to drive her for almost a week
Uriyo_
Sep 8, 2021 08:46 AM
