Eibach sportline ok to go with stock shocks ?
Old Dec 13, 2009 | 02:39 PM
maxevo's Avatar
maxevo
Default Eibach sportline ok to go with stock shocks ?
I'm intrested in purchusing a set of eibach sportline's which from searching is the perfect drop i'm looking for. I have crossed coil overs outa my head because i'm not looking to go that low and adjustable dampning and all that will not come into play for me in specific.
My question is if i get the sportlines will they last with my stock shocks ? or should i get new shocks ?
I'm trying to be cost effective i know some people are gonna thorw really expensive shocks at me but i'm just looking for the drop and shocks that wont blow on me after couple months of usage.
Old Dec 13, 2009 | 02:52 PM
Z_Nick_Z's Avatar
Z_Nick_Z
ive had sportlines installed with stock shocks for about a year now and i have had zero problems. The right isnt to harsh and the drop is perfect.
hope this help
Old Dec 13, 2009 | 03:16 PM
jimpactmfsc's Avatar
jimpactmfsc
they should work fine a friend of mine has had his on stock shocks for about 3 years now,
word of advice, if your buying springs dont waste anytime or headaches, get a rear camber kit as well while your at it
Old Dec 13, 2009 | 04:15 PM
diablox1's Avatar
diablox1
the stock shocks will definitely wear out over time, and will do so much much sooner than tokiko, kyb, or whatever other performance shocks are out there. stock shocks weren't designed to compress as much as eibach springs will let them.
Old Dec 13, 2009 | 04:28 PM
maxevo's Avatar
maxevo
thank you for the comments ! if anyone else has more feedbacks to include please write.
Old Dec 13, 2009 | 04:43 PM
terrasmak's Avatar
Is the car being lowered? Are the spring rates being increased ? Guess what, they won't last long!! Maybe 5k miles, and the people who say they have been running them for years, are on blown shocks and just don't know it.
Old Dec 13, 2009 | 05:58 PM
Why not. Shorter springs simply reduce the maximum extension of the shock.
Old Dec 13, 2009 | 06:09 PM
twitch579's Avatar
twitch579
Ive had them for about 50k miles with the stock shocks. Im at 95,000 miles now and my shocks have just recently went out. Its all bouncy on the highway and my handling has went to crap. I dont think the shocks went from the springs though, I think just the mileage in general has killed them.
They were perfect for the longest time, the ride was super stiff with Zero body roll. It felt like a race car. Im ordering at set if Tokico blues after the holidays are over.
Old Dec 13, 2009 | 10:47 PM
terrasmak's Avatar
Actually your struts were really worn about at about 60k, probably before since you installed the springs at 50k, but completely blew now.
Old Dec 14, 2009 | 05:42 AM
brandon3434's Avatar
brandon3434
search
Old Dec 14, 2009 | 10:19 AM
maxevo's Avatar
maxevo
if you use the search function you can see there is nothing in regards to sportlines and stock shocks. 2 topics with 2 posts in each that are useless.
Originally Posted by brandon3434
search
Old Dec 14, 2009 | 11:29 AM
Manu's Avatar
Manu
With shorter springs, your stock shocks have to do more work than before with 60-70 % of their normal movement range. You need shorter shocks that match the length of your shortened springs.
I got the Eibach sportline with the Bilstein B8 shocks and I am very very happy with the results.
Old Dec 14, 2009 | 11:45 AM
Lcat84's Avatar
Lcat84
'nuff said
/thread
Old Dec 14, 2009 | 01:01 PM
sinister350z's Avatar
sinister350z
This is an idiotic statement.
Old Dec 14, 2009 | 04:45 PM
terrasmak's Avatar
actually its the truth, but ignorance is bliss your your trying to mod a car with your pockets turned out.
Old Dec 15, 2009 | 04:47 AM
Lcat84's Avatar
Lcat84
This doesn't mean that the shock's life is going to get significantly shorter.
Old Dec 15, 2009 | 06:37 AM
brandon3434
you are wrong, because I have answered this question before in more than one previous thread...
Old Dec 15, 2009 | 11:25 AM
terrasmak's Avatar
Lets see, drop spring still have preload, so maximum extention is not affected. The only way to affect extention like that would be go to less than 0 preload on the spring.
I'll make this simple for the common idiot to try understand it.
Increasing spring rate and changing the starting point of the movement range for the shock piston will wear out a shock that is not designed for that application very fast.
Look at Manu's post, also helps out. Usually the shocks arn't shorter , they are just designed different internally for lowered application.
Old Dec 15, 2009 | 05:29 PM
maxevo's Avatar
maxevo
instead of being sarcastic , try being helpfull and post the link in which you say you have answerd this
Old Dec 15, 2009 | 09:39 PM
brandon3434
I wasnt being sarcastic at all...I was serious...
Whenever you lower your car that much on stock shocks, it puts more stress than normal and will make the shocks wear out faster. Eventually you will need to get better shocks, but how long it takes is different for everyone. For me it took only about 10k miles with the sportlines on, then i got dspecs...
In my opinion, just get the shocks and springs at the same time, you will like the ride wayyyyy better with better shocks...
