spring mount question
Old Jan 26, 2010 | 10:06 PM
mrfobbyaccent's Avatar
mrfobbyaccent
Default spring mount question
Hey just wondering how many of you guys on coils use your spring mount or not?
Old Jul 31, 2010 | 07:20 AM
htownimports's Avatar
htownimports
i want to bump this question because i'm kind of stuck on the same thing...
Old Jul 31, 2010 | 09:13 AM
terrasmak's Avatar
All depends on the kit. My kit doesn't use it and i couldn't install it if i tried. Others need it and you couldn't properly install your system without it.
Old Jul 31, 2010 | 12:08 PM
Gsedan35's Avatar
Gsedan35
If the kits uses the mount, use it. If it doesn't, don't.
If your wanting additional rear drop and your setup uses the rear upper spring seat, go ahead and cut the seat down.
Not running the mount won't end the world on kits that are supposed to use it, but you'll get noise from sharp impacts like tar strips. And I wouldn't guarantee no spring movement in the upper seat pan under the right condition's. I've run without the upper mount when testing, but I alway's had rubber shims I made to keep the spring in place.
Old Jul 31, 2010 | 12:35 PM
marques1's Avatar
marques1
+1 and also remember if you do the spring mount cut mod you will most likely need camber arms to get back in spec.
Old Aug 6, 2010 | 07:24 AM
htownimports
anyone with Function Form used their springmounts? want to get an answer before making a new thread, thanks
Old Aug 6, 2010 | 12:19 PM
GeauxLadyZ's Avatar
GeauxLadyZ
^ Does kit say to use it?
Old Aug 6, 2010 | 02:45 PM
htownimports
bought the kit used, didn't come with instructions
issyz
Jul 2, 2017 03:04 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
