adjusting rear dampers
Hey everyone I was messing around with my car today. i was trying to adjust my rear shock, because there was play between the spring and the body. I didn't end up fixing it, I just took everything a part and put it back together. While messing around with my shock I think I made my stiffness harder. It is to stiff for me, and I want to make it softer. I read some where in a thread that you do have to take of the rear tire, but I can't find that thread anymore, and I can't seem to find it anymore. Any input would be great everyone thanks!!
btw I am on sma coilovers thanks
Angelo
Angelo
You would need to ask SMA where their damper adjustment is or just look at the damper itself - every coilover is different. Some are done at the top, which means you either have to remove the shock and adjust it, then reinstall the shock; or drill a hole in the rear strut brace, and use their supplied tool/screwdriver/whatever to adjust things. If it is done at the bottom, again, it depends on your specific unit. Some require the wheel to be removed, some don't - that's a function of the wheel you have and where the adjustment **** is located
Angelo
the plastic all snaps apart you just have to be careful that you don't snap the clips. Easiest way is to get a tool from an auto parts store - they make ones that are designed specifically to remove such panels.
you will need to either remove the shock or drill the hole in top that lines up with the adjustment screw on the damper
but before you touch any of that stuff, you need to get with the company and figure out why you're still having height issues - there should not be any play whatsoever between the spring and the body
but before you touch any of that stuff, you need to get withthe company and figure out why you're still having height issues - there should not be any play whatsoever between the spring and the body
hey mrfobbyaccent... the adjustment **** for the dampening is right below the uppermount. just jack up the car enough to slide your arm into the gap and pull down the dust cover. you should see the ****...
Ohh thanks man I didn't realize that. I think I have a found a way to fix our problem with the spring sitting loose. I am pretty sure our shocks are set for the highest setting ride height so the shock has full play. If we just adjust the shock an inch or two, it should bring the spring up so that there won't be any play for the spring to bounce around. I was trying to do this on my own, but too much work, and I had to leave for work. Thanks for the info jkebun. Ill let give you more info when I get it fixed.
