question regarding pad return lever
Old Feb 16, 2010 | 10:56 AM
ttbbsolid's Avatar
ttbbsolid
Default question regarding pad return lever
Hi all.
Hope all is well with you guys.
I have a question on brake pad return lever on the front brake.
I was helping my friend's altima front brake pad change and I noticed there are two brake pad return lever (on the top part) for both inner and outer pad.
The brake pad my friend got had wear indicator on inner pad, but not on the outer pad.
Do I put that return lever ONLY on the pad WITH the indicator on it?
Or do I just put the return lever on both pads?
Your help is greatly appreciated.
Thanks guys.
Old Feb 16, 2010 | 12:42 PM
Z04's Avatar
Z04
considering the altima brakes are not the same as a 350z i suspect you will find it hard to get a accurate answer. try asking this on a altima forum
Old Feb 16, 2010 | 04:20 PM
terrasmak's Avatar
If it only has the one wear indicator it goes on the inside leading edge.
Old Feb 16, 2010 | 10:10 PM
ttbbsolid's Avatar
ttbbsolid
got it. thanks!
samansharif
Sep 25, 2015 12:31 PM
