ebrake, back brakes... ahhh frustration...
Old Mar 8, 2010 | 07:35 PM
nofearsuzki199's Avatar
nofearsuzki199
Angry ebrake, back brakes... ahhh frustration...
alright look i have a 2003 silver z. this past week i have put in a new driver side window motor, new passenger side door handle mechinism, back brakes and ebrakes. So, here is the problem. The ebrake has pressure and tension... but when i pull it, it hardly does anything. it will still roll on a small incline and after getting the rear brakes put on on the way home they was smelling pretty tuff.... and feels as if they are compressed against the rotor kinda i mean if u put it in nutral it eventual slows it to a stop... so whats up with the ebrake and is that normal to smell them after putting in brand new ones?
Old Mar 8, 2010 | 08:16 PM
SirSpeedyZ's Avatar
SirSpeedyZ
yikes, that's no good
hmmm, maybe you overtightened something on the rear brakes,
just did mine and it was pretty straightforward, but I have no idea about the ebrake
Old Mar 8, 2010 | 08:35 PM
nofearsuzki199
yeah i had someone do it for me they said that was normal... lol because they was new... i did the fronts... and they didn't do that... idk the only reason i let them is because they already had the ebrake suppose to be fixed and they already had the wheels and calipers off...
Old Mar 8, 2010 | 09:55 PM
terrasmak's Avatar
I would have to look at it to fix it, and the ebrake may be a simple fix.
Old Mar 8, 2010 | 10:05 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
The e-brakes are drum brakes within the rear rotor. The rear brakes are the disc part of the rotor.
It sounds like your e-brake just needs to be adjusted and has nothing to do with your rear pads. Check the Factory Service Manual for a how-to.
Old Mar 9, 2010 | 08:51 AM
nofearsuzki199
thanks
Old Mar 11, 2010 | 08:23 PM
fiddi1's Avatar
fiddi1
I just adjusted the ebrake on my friends G coupe. There is a black rubber cap on the rotor/disc. Remove it, then rotate the whole hub to find the adjustment **** inside/behind the rotor hat. Use a flat screwdriver to adjust the ****...I believe you need to push down on it to tighten the pads until it makes contact to the inside surface of the rotor hat. Rotate the hub until you feel a slight drag from the pads indicating it is making some contact. Apply ebrake, rotate hub to test. If you cannot rotate by hand, it is probably adjusted. Put back cap/wheels. Test again by turning engine on and place in drive with ebrake engaged. Car should stay stationary.
Do these first prior to adjusting:
1.Jack up the car (rear). Place wheel chocks to front wheels to prevent rolling.
2.Remove rear wheel/s
3.Make sure ebrake is disengaged. Put car in Neutral gear.
sales@czp
Sep 23, 2019 03:30 PM
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
