STANCE GR+ Pro Problem
Old Mar 28, 2010 | 01:08 PM
BrazenZ's Avatar
BrazenZ
Sorry ryaann, are you saying the threaded shaft was loose or the nut (not bolt) itself?
Old Mar 31, 2010 | 05:54 PM
BrazenZ's Avatar
BrazenZ
After taking the suspension apart for other mods, we discovered a bad wheel bearing on the driver's side. It was probably a contributing noise, but there was also noise coming from the Stance coilover. I tighten the spring as KrammyKram suggested. One full turn of the spring lock nut ( We could still turn the spring by hand but not easily. We put the rear suspension back togather and after a 40 mile drive, I happy to say that damn clink noise is freakin gone
Old Apr 1, 2010 | 07:08 AM
tsar's Avatar
tsar
I'm running the Stance AL+ true coilover rear and I'm having this knocking issue on my driver side rear. Still haven't been able to pinpoint the cause. I tried tightening the spring lock nut to no avail and visually it doesn't look there might be anything loose. I'm going to try swapping the passenger and driver side rears this weekend and see what happens. First I'll try loosening the endlinks to see if that might be the problem. Any other suggestions?
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
