STANCE GR+ Pro Problem
Old Mar 20, 2010 | 07:22 PM
ryaann's Avatar
ryaann
Default STANCE GR+ Pro Problem
I just got them, put them on. I am on the 2nd to the stiffest setting. I am running on stock tires and rims for an 05z. It is lowered SLIGHTLY.. very slightly.
Problem: As i am driving, i can feel every hit. (I know this happens.) BUT, i hear like a metal click. Like a metal piece dings another, and it only happens in the rear.
I drove it back to the garage, jacked it up, tried to shake the coilover left and right, back and forth. Nothing. Tried to check the bolts with just finger tight and make sure none were too lose. Nothing. Only thing i noticed, the coil itself, the physical round peice, is extremely extremely close to the wall of my fender on the back. Like a centimeter away. Is that normal? Could that be hitting the wall on bumps causing the sound?
Any ideas? I appreciate it very much guys.
Old Mar 20, 2010 | 07:29 PM
TheFarmer's Avatar
TheFarmer
I would suggest checking the bolts with a proper torque wrench.
Old Mar 20, 2010 | 07:30 PM
ryaann's Avatar
ryaann
What's the LBS of force supposed to be at? We just used a breaker bar and got em as tight as we could
Old Mar 21, 2010 | 06:36 AM
BrazenZ's Avatar
BrazenZ
ryaann I had the same problem for quite sometime, and the same coilovers, It's a metal clicking sound and for me it only occurs when driving over cracks/ edges in the pavement, not on wavy or uneven roadway and only in the rear. I have called Stance and been to 2 different shops and still haven't found the answer. I periodically check my coilovers, inner fenders and mounting points for wear, rubbing, and banging marks, so far nothing. I had my shocks professional installed and they were properly torqued ( I don't remember the torque specs). Please post if you find an answer. BTW I have the valving **** set on the 2nd softest.
Old Mar 21, 2010 | 06:55 AM
kramykram's Avatar
kramykram
you need to tighten the springs. its the pillow ball mounts rattling make sure that you cannot move the spring. i did what stance said and tighten it just enough that you can still turn the spring and my pillow ball mounts started rattling.
Old Mar 21, 2010 | 08:37 AM
BrazenZ's Avatar
BrazenZ
That makes sense, I will give it a try, we had the springs where you could turn them by hand only because Stance told us not to preload the springs. Thanks Mr.Kram
Old Mar 22, 2010 | 06:01 AM
ryaann's Avatar
ryaann
looks like its 40lbs of torque. I will do that today! Thanks guys. Let me know brazenZ if it helps you
Old Mar 22, 2010 | 06:07 AM
blasian's Avatar
blasian
Probably the pillow ball mounts.
Old Mar 22, 2010 | 01:41 PM
BrazenZ's Avatar
BrazenZ
ryaann, I'm stuck offshore and won't be able to work on my Z's for another week, I will post my results good or bad.
Old Mar 22, 2010 | 03:36 PM
Chi-TownWarrior's Avatar
Chi-TownWarrior
Does anyone still have the instructions for the coilovers. I've been trying to get stance to email them to me all last week, and today. It's like they aren't sending them. Thanks
Old Mar 22, 2010 | 03:41 PM
ryaann's Avatar
ryaann
I do not. I will be doing it this Thursday, for now i will be riding around with the rattling.
Old Mar 22, 2010 | 04:10 PM
SuperBlack350z's Avatar
SuperBlack350z
i have the instructions but i would have to take a pic of it. i don't have a scanner or anything.
Old Mar 22, 2010 | 04:43 PM
Chi-TownWarrior
Something is better than nothing. PM sent
Old Mar 25, 2010 | 08:38 AM
ryaann's Avatar
ryaann
Is this the correct piece that needs to be tightened? The Pillow ball mount. I know its the stock one, but im using it as a reference.
Old Mar 25, 2010 | 08:45 AM
Voboy's Avatar
Voboy
I believe they're talking about tightening the bolts that hold the pillowball mount to the car... so your picture see the two holes (top and bottom from your finger) where you would bolt them to the car? tighten that.
Old Mar 25, 2010 | 08:55 AM
ryaann's Avatar
ryaann
Oh, gotcha. Okay man, i appreciate it!
Old Mar 25, 2010 | 11:06 AM
Tiltz's Avatar
Tiltz
Hey man this is a very common problem on the Z. My car did the clunk stock and now it has it with apexi coilovers.
A lot of people have asserted that it is the shock, or the mounting point, or the rear hatch. Here is a massive thread with alot people with the same problem and a bunch of different solutions (going to the dealer and replacing various suspensions parts) which never seem to last.
https://my350z.com/forum/maintenance...g-in-rear.html
This thread seems to address the issue pretty good and seems like it should actually fix the problem. It also expains the variations of the problem between cars and how it is related to how tight the tolerances are in the suspension. For example some people get excessive clinging coming from both rear corners on every bump and some only experience slight clunking sometimes on the passenger side. This is probably due to how much play there is between the bolt and the shock and the pillow mount and body.
https://my350z.com/forum/maintenance...e-for-4-a.html
Old Mar 25, 2010 | 07:49 PM
ryaann's Avatar
ryaann
Mine is gone. It was just a lost bolt on the top of the pillow ball.
Old Mar 26, 2010 | 07:12 AM
BrazenZ's Avatar
BrazenZ
ryann, could you be a little more specific, what bolt was lost? are you referring to the bolts that attach the pillow ball to the fender?
Old Mar 28, 2010 | 05:45 AM
ryaann's Avatar
ryaann
Sorry not lost, Lose. The top bolt, above the hat itself. The piece im pointing too in that picture was lose, and the ring below the hat was rattling up and down.
