need help Please, suspension broke
I had a little accident a few days back when it was raining and some parts of the rear left suspension broke, can you guys tell me the name for these two parts to see if I can find them please. Thank you in advance.
ouch.
the component in the first pic is called the "midlink". it usually holds the spring--you might need one of those too lol.
the next pic shows the "rear suspension knuckle" broken off. the arm that is holding the broken knuckle peice is the "rear traction rod".
i would also replace the "camber arm" as it may have been bent as well. don't be shocked if the axle shaft and that side wheel bearing were damaged as well.
ouch.
brand new oem parts:
http://www.courtesyparts.com/350z-pa...5_800_804.html
looks like you already found this:
https://my350z.com/forum/suspension/...sub-frame.html
350Z_Al
Oct 29, 2020 07:44 PM
