Checking brake pad thickness
Old Mar 28, 2010 | 04:50 PM
confusa's Avatar
confusa
Default Checking brake pad thickness
Read through a bunch of posts but couldn't find an answer. Is there a simple way to check pad thickness for wear. For instance, on my last ride a GTI, when you couldn't fit two pennies between the backing and the disc the pads needed to be replaced. Anything similar on the 350?
Old Mar 28, 2010 | 05:22 PM
DavesZ#3's Avatar
DavesZ#3
Visual is the easy way - you can look through the caliper to see the pads. Take a small mirror and position it between the spokes of your wheels and estimate how much is left. I believe factory thickness is 8 and 11 mm (depends on type and F/R) with a minimum thickness of 2mm.
No mirror - then you'll have to remove the wheels and check them visually that way.
Old Mar 28, 2010 | 07:37 PM
You can look in the window. You can eyeball 2 mm. Bedsides I don't worry about it until I hit the audible wear clip.
samansharif
Sep 25, 2015 12:31 PM
