Tein Mono Flex help
Old Apr 5, 2010 | 10:17 PM
wbama387's Avatar
wbama387
Default Tein Mono Flex help
So I just installed my tein mono flex and noticed on the front that I only have one inch of travel on the shock absorber before it hits the bump stop. Is this normal? The only thing I can think is that the spring is stiff enough that it won't travel that far upward. Thanks in advance.
Old Apr 5, 2010 | 10:52 PM
heyyouduh's Avatar
heyyouduh
did you set the spring preload according to tein's instructions? if so, then that should be fine.
Old Apr 5, 2010 | 11:04 PM
blue350zed's Avatar
blue350zed
This is true. OP- set 'em up as suggested in the manual and you'll be fine. I tweeked one corner afterwards to get it all level and have been running fine for 3 years now.
Old Apr 6, 2010 | 10:33 AM
terrasmak's Avatar
Just wondering , how much of a drop do you have?
Old Apr 7, 2010 | 01:46 PM
wbama387's Avatar
wbama387
Not much if any at all. I do have a g35 so I don't know if that makes a difference. I might be at stock ride height I didn't measure before hand though. I will check teins specs but from my understanding on the front coilovers you want to be able to just barley twist the spring when there is no load on it. Then you move the shock absorber in or out to adjust the ride height.
Bodyboarder81
Nov 2, 2015 12:17 AM
nanotech
Oct 2, 2015 05:02 AM
