how to set up your handling. (basic)
Old Apr 9, 2010 | 08:40 AM
supergoji's Avatar
supergoji
Default how to set up your handling. (basic)
figured i'd post this because everyone with a performance suspension and anyone who does spirited driving should know about this.
To Increase Understeer (reduce oversteer)
Stiffen: front springs, front compression damping, rear rebound damping
Soften: rear springs, rear compression damping, front rebound damping
to increase oversteer (redunce understeer)
Soften: front springs, front compression damping, rear rebound damping
Stiffen: rear springs, rear compression damping, front rebound damping
adjustment points
Bump: This controls the stiffness of a shock relating to compression. Sounds just like a spring, and it pretty much is. The difference being that while a spring's stiffness always has the job of holding up your car, the shock's bump setting only acts on temporary forces likes bumps and roll. Adding more bump will act very much like stiffening the spring on the same corner.
Rebound: This controls how quickly the spring descends after compression. This is a VERY important setting when tracking a car. Without enough rebound a spring will hop and skip along the ground, making it hard to put down power, braking or cornering force. If you have too much rebound, the spring will not be allowed to expand quickly enough to return to its proper ride height before the next input. Too much of this will lead to "jacking down", which is a term for when a vehicle lowers itself until it is riding on it's bump stops (hard rubber, used as a last-ditch safety feature to keep tires from rubbing on very hard bumps). You can use rebound to control roll. By increasing rebound you decrease the velocity of the spring's expansion. If the spring cannot expand, it cannot push that side of the vehicle up. So the vehicle must either not roll as much, or lift its inside tire. Obviously you don't want to set so much rebound as to end up with the latter.
Sway bar settings: Increasing a sway bar's stiffness will reduce roll, but also increases the sprung tension on that axle. Granted, most of the increase in tension is apparent only when there is body roll - but even statically there is an increase. This means you must modify your rebound settings when you change your sway bar settings (just as you must whenever you add spring tension).
Camber: This is a tire's difference from vertical when looked at from head-on. + means the bottom of the tire is in more than the top. - means the bottom is out more than the top. Remember, this setting is only accurate when the car is NOT moving. As the wheel moves with the suspension, the camber will change depending on the geometry of the suspension. What is important is observing how the tire wears, and by taking tire temperature readings on the outside, center and inside to make sure that all of the tire is being used when it is at full load.
Castor: This is the difference between a wheel's centerline and the axis of suspension travel on that corner when viewed from the side. This is rarely adjusted on a street car. The more forward the wheel's centerline relative to the suspension's axis, the better the car will soak up bumps. And the more it will nosedive when you hit the brakes. The reverse is also true.
Toe: This is the difference between the direction a tire is pointing and straight ahead, when looking down from above. + means the tire points in. - means the tire points out. Positive toe makes a car more stable. This is useful at higher speeds and for general steering comfort. Negative toe makes a car more darty. This is useful to initiate quick directional changes, but can also reduce your total level of grip with excessive tire scrub (more on that later).
Options
Reduce understeer:
-Enter turns slower! Then power out.
-Reduce front tire pressure, and/or increase rear tire pressure.
-Reduce front spring tension, and/or increase rear spring tension. This can be done by swapping springs, or by changing sway bar settings/diameters.
-Reduce front bump, and/or increase rear bump.
-Reduce rear camber, and/or increase front camber.
Reduce oversteer:
-Do the opposite of the above "reduce understeer" options.
Reduce roll:
-Increase tire pressure all around.
-Increase bump settings.
-Increase rebound settings.
-Swap springs for stiffer ones.
-Increase sway bar settings/diameters.
Increasing traction for applying power:
-Reduce rear tire pressure.
-Reduce rear spring tension.
-Reduce rear bump.
-Increase rear rebound.
-Reduce rear sway bar settings/diameters.
Increase braking traction
-Reduce tire pressures.
-Increase front spring tension.
-Increase front bump.
-Reduce rear rebound.
-Reduce all sway bar settings/diameters.
Old Apr 10, 2010 | 05:30 PM
crsracing19's Avatar
crsracing19
make this a sticky good info
Old Apr 11, 2010 | 04:38 PM
gorillagoggles's Avatar
gorillagoggles
Very useful info, thanks for doing this!
Old Apr 12, 2010 | 04:00 AM
dennisafrompa's Avatar
dennisafrompa
..always remember though, ONE change at a time. Then eveluate and change again if necessary.
Old Apr 12, 2010 | 02:16 PM
Thermal1's Avatar
Thermal1
I think this calls for a STICKY
Old Apr 27, 2010 | 03:48 PM
scareurpasenger's Avatar
scareurpasenger
This is missing one minor thing. If you increase camber too much on the front it will reduce braking or in the rear it will reduce traction.
Old Apr 28, 2010 | 06:54 AM
akomsr1's Avatar
akomsr1
Please keep in mind that shock forces have opposite effects during corner entry and corner exit. Springs and swaybars will have an overall effect on all cornering phases
Example:
-Increasing front rebound will make the car tighter on entry, but looser on corner exit
-Increasing rear compression will make the car looser on corner entry, but tighter on corner exit
