Installing springs. Question about rubber washer
Hello,
I'm trying to replace the stock springs with Hotchkis springs. After putting the front strut/spring back, I found a black rubber washer on the floor. Where does this rubber washer belong to? Thanks for the help.
Black rubber washer
Black rubber washer
This is the closest thing I could have found in the Factory Service Manual for you. I have yet to replace my front springs (will be doing that this weekend). Which I do not know if it is that, in the picture it looks to be a bit different. Unless its up there where the upper mount goes. Hopefully that helps a bit if not somebody else will definitely chime in.
That's what I was thinking as well, but for which side of the upper control arm? Does anyone have a specific answer to where this should go?
Does it go on between the right side of the control arm and the engine side like in the picture below?
NOLAGG
Misc.
Sep 28, 2015 04:14 PM
