Carb cleaner on brake parts
Old May 17, 2010 | 08:24 PM
jbh1's Avatar
jbh1
Default Carb cleaner on brake parts
OK,
I messed up a little. I was installing new pads on the front brakes and I grabed a can of what I thought was brake cleaner. I sprayed some around the caliper pistons by the rubber seals before I backed the pistons back into the calipers. I also sprayed a little on on the rotors to make sure they were grease free from the install. I was not until I was putting everything up that I noticed I used the wrong can (they are both oreillys brands so they have the same color scheme).
I backed my car out and ran water over the calipers but this was after everything was installed, wheels and all.
Any chance I damaged my piston seals, that is the only thing I can think of where this could be an issue. None got on the new pads.
Old May 17, 2010 | 10:58 PM
SHIVtheGREAT's Avatar
SHIVtheGREAT
What was the other stuff?
Old May 17, 2010 | 11:01 PM
SHIVtheGREAT
Nevermind... just read the title of your post. I've heard carb cleaner is the exact same ****. I wouldn't worry about it.
http://www.ehow.com/video_2327168_cl...ke-rotors.html
Old May 17, 2010 | 11:27 PM
terrasmak's Avatar
Your fine, i use carb cleaner all the time on brakes and brake cleaner on carb. Depends on what one is cheaper.
Old May 18, 2010 | 01:16 AM
Spork's Avatar
Spork
You're fine.
Old May 18, 2010 | 03:41 AM
jbh1's Avatar
jbh1
Thanks everyone!
_bit
Oct 2, 2015 07:49 AM
