KW v3, rebound adjustment up top?
Old May 25, 2010 | 12:30 PM
2fasst's Avatar
2fasst
Default KW v3, rebound adjustment up top?
I'm needing/wanting to access the adjustment for my rebound on the KW V3. I believe it's up top of shock body. IF that's the case, anyone tried drilling holes into your chassis to access them? (rear shocks)
Also, the compression adjustment. I know it's at the bottom. But I'm not sure if it's on the external resevoir or if it's the adjustment that covered by a plastic snap on 'collar'?
any help is appreciated! their manual sucks. Half english, half german and it's a generic manual that's not specific to any/either models that they offer.
Old May 25, 2010 | 02:35 PM
Chebosto's Avatar
Chebosto
1. do you even have v3s installed?
2. yes. you can drill the rear strut tower brace for access to the top of the suspension. the adjustment is on top of the piston.
i made a custom 2mm hex tool that was very very tall to access the rear suspension. the stock adjustment tool they give you can work, just you risk dropping it into the strut tower area...
3. the rear compression adjustment is covered by a black snap collar. and its a 1/4 turn each sweep from left most opening to right most opening..you can't miss it
these are my Clubsports, i think the bump adjustment is in the same area.
bottom of the picture, next to the blue dot. pop the black cover off to access it.
the manual is actually pretty informative. and has images that show the generalized location of the adjustment areas...
Old May 28, 2010 | 12:38 PM
2fasst's Avatar
2fasst
thanks Chebosto, that post helps alot and confirms before I start drilling my chassis.
Yes, unforntunately I also have the Clubsport. I say unfortunately because in hindsight I believe the V3 would be better suited for my type of driving, which is daily driving. The reason why I inquired about 'v3' in my original post is because external they're identical and I figure I would get better response because the V3 would be more popular.
I find the Clubsport too harsh for my taste. What did I expect right? I know, I know. More isn't always better.
Curious what kind of settings you're running for street setup? How many clicks from full for rebound and compression front and rear?
Thanks again. I'll drill those holes to access the rear rebound adjustments.
350Z_Al
Oct 29, 2020 07:44 PM
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
Depravity
Oct 1, 2015 04:49 PM
