Brake/Clutch Fluid
Hey guys, first... I hope this is the right area to post this... if not please feel free to move moderators...
Im changing ALLLLLL my fluids this weekend, and tried the search button to find any threads on brake fluids or clutch fluids people have used, and couldnt find anything...
QUESTION IS: Is there a specific brand fluid I should use on either? DOT 4? What name brand? Im new to the Z, not new to cars... I just dont want to mess any of this up. lol.
Thanks!
Thanks!
sounds good, thanks guys, i researched just a taaaaad more, and just now found out to use the DOT3 fluid.
Also... sorry if this is such a noob question... but isnt the clutch fluid AND brake fluid the same? Im thinking of getting the ATE Super Blue fluid, and can be used the same right? Just looking to top it off... not bleed it quite yet.
Thanks
Thanks
just added some Prestone DOT3 brake fluid to my brake fluid reservior, and clutch fluid reservior. seems like the clutch is more engaged... may just be me?
I still have to do my trans/diff fluids, once i do that im sure itll feel like new! thanks to those who helped, I just wanted to update this for those it could possible help in the future
Dot 3 will work just fine, so will Dot 4. With that said, i change all my cars out to Dot 4 , it only costs a few extra cents but i can be hard on the brakes in the mountains. My Z I run off the shelf Dot 4 in my clutch and ATE blue for brakes, Do not run a high end Dot 4 like Motul or ATE if you just daily drive. They require frequent bleeding and the fluid is prone to absorb water faster than the normal Dot 4. It will also just cost you extra money you don't need to spend.
xirtam
Oct 3, 2015 02:06 PM
MyZ2Slow
Mid-Atlantic Marketplace
Sep 9, 2015 10:17 PM
