See if these fit
i need to order fr/r brake rotors today. I'm looking at "CENTRIC PREMIUM BRAKE DISC, FLOATING TYPE, SOLD INDIVIDUALLY -- 5 x 114.3 mm bolt hole pattern; 295.7 mm outer diameter; 12.9 mm bolt size; 22 mm minimum thickness; Manufactured to meet QS and ISO Quality System Standards; Utilizes an Electrocoating finish." And "CENTRIC PREMIUM BRAKE DISC, FLOATING TYPE, SOLD INDIVIDUALLY -- 5 x 114.3 mm bolt hole pattern; 291.8 mm outer diameter; 12.7 mm bolt size; 14 mm minimum thickness; Manufactured to meet QS and ISO Quality System Standards; Utilizes an Electrocoating finish"
Will they fit my 05 std 350z? I read the FSM and the outer diameters are like .2 mm off.
Floating is a type of rotor design made to reduce vibrations. Mainly when you think of floating you think of 2 piece with bolted hats. Slotted/drilled (is that what you mean by "vented"?) is something different.
Most websites will have you put in your car info and then find right part for you. Do that and be done with it.
i put my car and they came up with floating type. idk if mine has 2 pieces with bolted hats..
When i said vented, i meant ventilated rotors instead of soild rotor. Ventilated rotors have ventialtion between inside and outside of rotors.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
