Bc Racing which series? which springrate?
Old Jul 1, 2010 | 10:56 PM
donleguano's Avatar
donleguano
Default Bc Racing which series? which springrate?
Hello everybody
i wanna buy now my bc-racing coilovers...
i dont know which series i have to buy the BR, RM or ER...?
What kind of springrate should i go with?
i want to slam my car really low...and i dont want that my tires will rub...
i have these wheel dimensions:
19x9 +10 225/35
19x10 +10 255/35
hope you can help me...
Luca
Old Jul 2, 2010 | 12:22 AM
hellsoldiers08's Avatar
hellsoldiers08
you may nee to role finders. What purpose you have to slam the car for??
Old Jul 2, 2010 | 12:39 AM
terrasmak's Avatar
Do 225/40 and 245/40 , roll your fenders and just get the BR series but get 10k rear springs (order the shorter ones) and your good. You may need (probably) some spacers.
Old Jul 2, 2010 | 11:01 AM
Voboy's Avatar
Voboy
alot of people want to know what offset fits their car and will it rub, tire sizes, blah blah blah. well every car is different and if you drop the car, increase camber etc. clearance will vary.
what i can tell you is if you don't plan on correcting your camber in anyway, your wheel specs will be slightly sunken in and spacers will be necessary for the look you're going for.
and i'll tell you now you will rub. why? b/c you're going to drop the car to the tire or rim and even if your flush enough to clear the fender, there's a spot of metal that is used to hold the rear bumper on that will basically rub on the bad bumps you get into.
but to answer your question its probably the bc-br 10/8k you want to go with... and maybe shorter springs b/c you wanna "slam" the car.
Old Jul 2, 2010 | 11:18 AM
VQpoweredZ's Avatar
VQpoweredZ
Can't wait to install mine! It's just trial and error with the rubbing issues. But definitely some modification is going to be needed when trying to go as low as possible.
Old Jul 7, 2010 | 01:47 PM
aloh's Avatar
aloh
If you just wanna slam the hell out of it, just go for the BR's. The other ones are kind of overkill for your needs.
I have the BR ones with the usual 10/8 rates with the standard length springs. Im tucking a little tire in the rear. The rears are nearly maxed for their lowering capacity though. If you want to go lower, then you're gonna need those shorter rear springs.
For me, the stance is perfect. Im actually rubbing in the front on some part in the fender wells... I have a cut going through the middle portion of my tire tread because of the rubbing I get when I corner hard. Its ok for now since I have plenty of tread for it to dig into...but when that tread goes away, its gonna be dangerous. See pic:
Ive got 19x9.5 19x10.5 +22 all around with 255/35 and 285/35 tires. I rub in the rear if i enter a steeper than usual driveway in the rear even though my fenders are rolled.
Old Jul 7, 2010 | 03:14 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
they only make 2 types BR and ER
they offer a lower version of the rear spring for those who want to really drop the hell out of the car (to the point where handling suffers). The standard springs will let you lower it about 2 inches
plan on rolling your fenders
Old Jul 17, 2010 | 12:14 PM
User 42426's Avatar
User 42426
does anyone know the stats for the lower springs as opposed to the standard springs for the br?
Old Jul 17, 2010 | 06:19 PM
Z1 Performance
Former Sponsor
Same
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Twenty4
Jan 17, 2016 01:20 PM
