New Product from Performance - Upper Control Arms 2.6lb's!!!!
Old Nov 14, 2003 | 04:26 AM
Jeff@Performance's Avatar
Jeff@Performance
Performance Nissan
Originally posted by raceboy
Yeah, sign me up!
Hey Steve... I already put you on the list!! I knew you would want a set. I get set one and you can have set 2!!!
Old Nov 14, 2003 | 06:09 PM
N74DV's Avatar
N74DV
what alloy are these??
Old Nov 15, 2003 | 12:47 AM
Grommit's Avatar
Grommit
Might be a dumb question but with these mods could you by chance adjust the camber so we could get rid of the feathering once and for all? I'm thinking if you can I'd easily buy a set.
Old Nov 15, 2003 | 06:41 AM
Jeff@Performance
Performance Nissan
The main purpose of these is easy camber adjustment. I will have some more info for you guys when I get back to the store on Monday, But I should have my first batch in the next 5 days or so and will post the install and show the adjustments etc...
Old Nov 15, 2003 | 01:57 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
This list below are the objectives they wanted to reach in development of these control arms.
__________________________________
1. The arm must be easily adjustable
2. The adjustment must be permanent and repeatable (no
sliders assliders can slip and no eccentrics as
eccentrics can rotate
3. Provide enough range for both street and race
4. Use aluminum for light weight
5. Make sure it is as strong or stronger than original
6. Use a ball joint so that the travel is as long as
original ( monoball type outer joints limit usable
travel)
7. Make sure it looks cool so people will want to buy
it
8. Use existing proven race car design
9. We wanted an adjustment method that a person could
have his streetset up and easily change to his race
set up on race day then go backand know that both
setting are repeatable.
They believe they covered all of these. Soon to come, pictures of instal and review.
Old Nov 16, 2003 | 05:29 AM
dwnshift's Avatar
dwnshift
um..... sliders slip!
Thats funny .....we have over 8500 race miles on our race car and that has never ever happened. If an arm is engineered and designed correctly it wont happen.
That would be the same as me saying that shims fall out.
Come on now Performance play nice i think your diggin a little here.
Old Nov 16, 2003 | 04:08 PM
Gsedan35's Avatar
Gsedan35
Hey, you made the risky move to start any tit for tat here by firing the first shot in all this.
Is nt that a Honda ball joint!
I love a little competition!
You should know better, which wasn't playing nice and was diggin a little itself.
Sad thing is your both good people, knock it off or both your bottom lines will suffer from turned off wallets. Our community doesn't need this. And I like both your companies,.........let's keep it that way.
Old Nov 16, 2003 | 04:10 PM
Jason@Performance
Performance Nissan
I like to wear shoes.
Old Nov 16, 2003 | 04:14 PM
ssk0771's Avatar
ssk0771
Jeff or Jason, Would this get rid of the feathering?
Old Nov 16, 2003 | 04:59 PM
dwnshift's Avatar
dwnshift
Bengals win
Old Nov 16, 2003 | 05:05 PM
John's Avatar
John
Feathering is supposedly affected by the shock valving, not the UCAs, but I could be wrong. I have no feathering now that I got ride of my OEM suspension.
As for UCA adjustability, I would much rather have sliders as they more easily adjustable that having to put in shims.
Old Nov 16, 2003 | 05:10 PM
Jeff@Performance
Performance Nissan
The S-Tune suspension seems to take care of the problem so far. I'm going to ASSUME that this will hold true with the adjustable arms as well. At least we will have control on the camber.
Old Nov 16, 2003 | 05:34 PM
Jeff@Performance
Performance Nissan
We will do a step by step install as soon as my car is back from the stereo shop. I think you will be impressed by the "shims" that are used. They have a male/female mating surface to prevent any slipping and make sure you can go from track to street setting easily and ALWAYS end up with the same setting you want.
Old Nov 16, 2003 | 05:39 PM
dwnshift's Avatar
dwnshift
Did i mention the Bengals????
Old Nov 16, 2003 | 06:01 PM
John's Avatar
John
That's great and all, but it isn't easy to adjust. Having worked on many cars with sliding camber plates, I prefer that option much more. In fact, I have yet to see a good quality slider plate "slip" at the track (unless it wasn't tightened). To me, using shims is the cheap alternative, and if I'm going to pay money for a UCA, it's going to have slider adjustability. Plus, having to change out the shims when I drive home from the track is going to be extremely cumbersome.
Old Nov 16, 2003 | 07:11 PM
sifuK's Avatar
sifuK
I thought aluminum bends easily especially with alotta heat? just curious
Old Nov 16, 2003 | 07:24 PM
John's Avatar
John
The OEM suspension is made out of aluminum. The suspension never gets that hot anyways...
Old Nov 17, 2003 | 06:43 AM
  #38
Todd@ProDyno's Avatar
Todd@ProDyno
Feel free to restart this thread...minus the trash talkin, k?
sales@czp
Sep 23, 2019 03:30 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
