NISMO Rims and LSDUnique Camber Rods
Old Nov 14, 2003 | 07:11 PM
FLY BY Z's Avatar
FLY BY Z
Default NISMO Rims and LSDUnique Camber Rods
Ok I will start by saying that NONE of the pics anyone has ever seen do the NISMO rims justice. They looks great in person and much better than I thought they would based on pics I have seen. Anyways, the rims with the Toyos makes a huge difference in the feel of the car especially around a corner. You can feel the extra tire under the car and it feels a lot more stable especially at speed. I have only really driven from SA to DFW so far and have not really put the setup to the test. I think I read that the Toyos are like 4-5 lbs lighter than stock tires and the NISMOs are about 8 lbs lighter than the Touring rims. This saves me a modest estimation of 45 lbs of unsprung weight which I likes.
LSDUniques Camber arms are the best. They are beefy and work like a charm. My camber and toe in the rear was WAY off after lowering the car. With the arms in the specs are right in the middle of Nissans recommended range. Perfect. Big thanks to LSDUnique!
Stock rods:
LSD's:
Quick shot of very dirty car and wheels after road trip back from SATX to DFWTX:
Old Nov 14, 2003 | 07:17 PM
zillinois's Avatar
zillinois
Sweet rims and big rubber. What more could you want. Looks tuff with all that tire in the back.
Old Nov 14, 2003 | 09:30 PM
Xeinth's Avatar
Xeinth
Very nice. I think the Nismo wheels have to be one of my favorites.
X
Old Nov 15, 2003 | 12:18 AM
MY350Z.COM's Avatar
wow those rods are really beefy compared to stock.
i would get em just so that i know they won't bend easily.
Old Nov 15, 2003 | 01:01 AM
Grommit's Avatar
Grommit
How much for those camber arms and where did you get it? Also do you know if you can fix the feathering problem with this mod? Anyone?
Old Nov 15, 2003 | 04:32 AM
lowrider's Avatar
lowrider
Yes, the Nismo wheels look great in person, your right a picture just doesn't do them justice. I put a set on my 6MT "G" with Dunlop SP9000s, and the handling has moved up a notch. Looks great, handles great, and no special orders. I paid $1,850 for my set.
Lou
Old Nov 15, 2003 | 05:26 AM
Grey Matter's Avatar
Grey Matter
What size are the wheels and tires?
Old Nov 15, 2003 | 05:40 AM
lowrider's Avatar
lowrider
The wheels are 18X8.5" front and 18X9.5" rear. I assume he's running 245/40 in front and 275/40 in back. Those are the recommended sizes, and the ones I'm running
Old Nov 15, 2003 | 07:10 AM
EL PAALO's Avatar
EL PAALO
Camber arms are great.
Wheels look awesome.
Old Nov 15, 2003 | 07:46 AM
FLY BY Z's Avatar
FLY BY Z
Thanks for the comments guys. For the camber rods, PM lsdunique. He makes them through his company. They are for the rear wheels, but he is also making some adjustable front (A-arms??) to adjust the front but they will probably be more expensive than the rear. It sucks because right now the only thing you can adjust in the front is the toe. You cannot adjust camber or caster. LSDunique will cure that soon.
Also, the rod that is replaced to cure the pulling to the right simply throws the caster of the right front wheel way out of the original spec. When on the alignment machine it showed -9.5 deg. out of spec!
Old Nov 18, 2003 | 08:37 AM
N74DV's Avatar
N74DV
did your alignment shop have aproblem with excessive toe-in when they shortened LSD's rods to pull out the negative camber?
Mine did. I had some pretty bad toe-in and had to modify my lower control arm to pull out the excessive toe-in.
Old Nov 18, 2003 | 12:42 PM
jaxxxx's Avatar
jaxxxx
lowrider. can you post some pics of the mismo wheels on your G?
Old Nov 18, 2003 | 04:23 PM
FLY BY Z's Avatar
FLY BY Z
No, they pretty much just got both aspects right into spec immed. No problem. The only problem they had initially was mounting the alignment machines on the wheels damage free. A lot of electrical tape is key.
Old Nov 19, 2003 | 07:50 AM
zwindsor's Avatar
zwindsor
Twisty addict
Here's a pic of mine. Same configuration but with traction bars too.
Old Nov 19, 2003 | 09:55 AM
FLY BY Z's Avatar
FLY BY Z
Except for the drivetrain we almost have the same car! What are your motor plans so we can do something different?
Old Nov 19, 2003 | 10:02 AM
zwindsor's Avatar
zwindsor
Twisty addict
Nah, I'm done. I've gone as far as I want or should
I'll have to live off the rest of you guys that are able to do more
Old Nov 23, 2003 | 11:22 PM
cfalcon's Avatar
cfalcon
Arrow Almost off topic
Err.... noob question, if you will:
Are the Nismo wheels lighter than the track rays?
And what are the respective weights, anyway?
On topic:
Badass.
Old Nov 24, 2003 | 03:09 AM
lowrider's Avatar
lowrider
Nismos are a little heaver then the Track Rays, because they're wider. (8.5" and 9.5") vs. (8.0" and 8.5"). It's a miniscule amount however. For all intents and purposes they are the same.
Lou
Old Nov 24, 2003 | 03:48 AM
FLY BY Z's Avatar
FLY BY Z
I think it's one pound or less but the width makes them better!
