Riddle of the ride height and the devil's wheel gap.
Old Nov 11, 2010 | 04:42 PM
Neimad's Avatar
Neimad
Default Riddle of the ride height and the devil's wheel gap.
Breaking my vow of never posting for this one. Car and myself went through a few mid-life/indentity crisisis this year and I have an unattractive mess on my hands.
So...
S-tune suspension
275/40/17 X 4
Livable front/ jacked up (literally) rear.
I can't figure out why its that high and the math is giving me headaches.
Its sitting pretty much at stock ride height 26.4/27.5 (spec is 26.81/27.56).
The tires are 25.7 overall diameter uninstalled 25.ish on the wheels.
Stock tires are 25.9/26.3 uninstalled; not sure about mounted.
At this point I'm probably going to get SLP mid-links+camber arms/swift springs matched to the front rate and drive it till tax time and then finish with __?___ coil-overs and the rest of the SLP goodness.
Any insights/temporary solutions/commiseration/flaming/joking/etc is welcome.
Attached Thumbnails Riddle of the ride height and the devil's wheel gap.-ride-he.jpg   Riddle of the ride height and the devil's wheel gap.-ride-height.jpg
Old Nov 11, 2010 | 05:11 PM
derekinthez's Avatar
derekinthez
Looks like a truck my friend!
Old Nov 11, 2010 | 05:14 PM
jduet's Avatar
jduet
good lord, put some superswampers on that bish
Old Nov 11, 2010 | 05:18 PM
GeauxLadyZ's Avatar
GeauxLadyZ
It is an optical illusion because your tires are same diameter all around. Its filling more than stock gap in the front, and less than normal/stock in rear. It just appears higher in the rear.
Springmount mod for temp fix of the rear. take 1/2 to 3/4" off the mount. Dont waste money on swift springs and just wait for coils.
Change front tires to smaller diameter for perm fix after coils.
Old Nov 11, 2010 | 05:45 PM
fakejojo's Avatar
fakejojo
Wow!
First post in almost 7 years!
Hahah, this is great!
Old Nov 11, 2010 | 06:01 PM
I also ran the numbers, and like you, the numbers and the photos do not match. The rear springs are properly installed? The spring-seat is correct?
Old Nov 11, 2010 | 06:18 PM
Neimad's Avatar
Neimad
Thanks David,
I threw a friends shop a bone for the install. I'll pull it apart tomorrow.
Old Nov 11, 2010 | 06:21 PM
FATPUBUS's Avatar
FATPUBUS
wow, what happened lol
Old Nov 11, 2010 | 06:31 PM
Originally Posted by Neimad
Thanks David,
ha ha...
Members have a habit of installing this progressive spring upside-down.
Old Nov 11, 2010 | 06:44 PM
Neimad's Avatar
Neimad
I checked spring orientation today. I think Nismo means something in Spanish so that probably helped.
Old Nov 11, 2010 | 08:05 PM
GeauxLadyZ's Avatar
GeauxLadyZ
Oo I missed the part about u being on stune. So was that it? Are they upside down?
Old Nov 11, 2010 | 08:09 PM
johnwigs's Avatar
johnwigs
17s... that is the optical illusion
Old Nov 11, 2010 | 08:29 PM
Steve-O Z33's Avatar
Steve-O Z33
Yeah, someone told me once that nismo in Spanish means, "the same."
Old Nov 11, 2010 | 11:43 PM
terrasmak's Avatar
Throw 275/40-18's on the rear and the illusion will go away. It will also handle real well.
Old Nov 12, 2010 | 07:40 AM
betamotorsports's Avatar
betamotorsports
A couple times at Cal Speedway and WSIR I had 350Z guys come by and tell me my car was sitting too high and that I needed to lower it to make it handle better.
They still said the same thing after I ran laps 6 to 9 seconds faster then them and their lowered cars. BTW... in that picture the car is running 285/30-18s all around on stock springs.
Old Nov 12, 2010 | 08:12 AM
Neimad's Avatar
Neimad
There's autocross at the Coliseum this Sunday. If nothings wrong with the springs I'm going.
Old Nov 12, 2010 | 03:35 PM
Neimad's Avatar
Neimad
Took driver's side apart, no 1" block of wood under spring like I was hoping.
Almost cut the mounts but didn't have a precise way of doing it. Also it seems ghetto.
Can someone measure a stock 17" with 235/50 overall diameter for me?
This is so I can compare what my theoretical S-tune+stock wheel tire gap is to pictures of other S-tune/stock gaps.
Old Nov 12, 2010 | 04:21 PM
terrasmak's Avatar
http://www.1010tires.com/TireSizeCal...?action=submit here you go
Old Nov 12, 2010 | 04:39 PM
Neimad's Avatar
Neimad
That's uninstalled/no weight on it. The 275/40/17s I have are listed at 25.7 total diameter. On the car they are just over 25. So the stock tires are 26.3; I'm assuming they compress similar to about 25.7...so I gain .6ish wheel gap. Right now it does need gas but I measure at:
Front 26.25 with 1.5 gap.
Rear 27.75 with 2.75 gap.
The ride height does not make sense. It should be -.8 from the springs and -.35 from the sidewall reduction.
Old Nov 12, 2010 | 08:41 PM
BrazenZ's Avatar
BrazenZ
When I swapped from my 255/35/19's front, 285/35/19's rear to 255/40/17 all around (Before I dropped it and had it realigned) I looked liked I was driving a 4-wheel drive 3/4 ton Z.
