Rotor stuck - trying to remove
Hi guys, my rotor is stuck right now as i'm trying to remove them. I don't really want to hammer them as i'm going to be reusing it after resurfacing.
There's 1 pinch bolt hole on the stock non-brembo oem rotor, and i've heard people say to use a bolt, screw it in and it'll force the rotor off. Has anyone tried this method and know what size bolt to use or where i can find the bolt?
Here's a picture of the oem rotor
Try some PBblaster spray around the hub/rotor joint. Let it soak in for a while then use a board against the rotor and hammer it so you don't damage the rotor.
You should be able to take the OEM bolt out, remove the sleeve then screw it back in so it contacts the hub and will start the rotor off.
squirt pb blaster where the hub meets the rotor and wait a little bit for it to work and try again. You may need to use a soft-blow mallet to "help" it release. I've never tried the bolt method, but I had the same problem and pb blaster and a mallet worked.
The bolt method is the easiest up front, and like Dave said, its already their for use. Just pull it , remove the sleeve and tighten it down till the rotor pops off.
is it necessary to do that in order to remove the rotor?
i've searched the file br.pdf in my 2007 service guide but cannot find the section for removing brake rotor... is it in a different file?
lol cause i remember i had to replace a stud. the rear rotor wouldn't come off. it was because i forgot to release the emergency brake. lol... i was scratching my head for a sec. once i release the emergency brake it practically fell off. lol.
what confuses me though is that i've already released the parking brake, shouldn't this make the parking brake loose? why do i have to use a screwdriver and loosen it more?
Keep removing bolts until you find one that works. I don't know what size works, but I recall it takes either a 12mm or a 13mm hex head bolt that you typically find on any Nissan.
The correct way to remove the rear rotor when it is frozen is making use of a 2 paw gear puller. set it in the largest setting and use it to pull the rotor just enough to notice that the rotor is lightly flexing, then "tap" the rotor with a hammer and watch the rotor jump off the rear with a loud pop. I had to do this just about every single z/g that never had their rear rotors removed before.
ya after an extensive search i'm going to try the emergency brake method and leave the hardcore banging as last resort....
