A'pexi N1 EXVcoilover install
Old Jan 5, 2011 | 08:32 AM
arsey51's Avatar
arsey51
Default A'pexi N1 EXVcoilover install
Hi guys, looking for some suggestions here. I recently had the Apexi coils installed a few weeks ago and also recently had an alignment done at Precision Z. My problem/concern is the rear end, on uneven pavement, especially on our wonderful so cal freeways, it feels like the rear end is floating from side to side. The Apexi's are similar to other coils in that they use the same setup as stock, i.e., seperate damper and spring. The install manual clearly states that when adjusting ride height, that both the spring and the damper should be adjusted. Could the floating feeling be due to the damper and spring not being in sync as far as length? If anyone out there has had a similar experience and corrected it, let me know. Other than the floating issue, the coils seem fine. I had the damping set too stiff at first, 24 out of 32, then backed it down to 16, right in the middle and much better ride. Any suggestions/feedback on the floating issue is greatly appreciated.
Happy New Year
Jim
R/T Tuning
Suspension
Dec 24, 2012 07:31 AM
abstrakt
Tuning
19
Feb 3, 2005 08:25 AM
