anybody having hard time taking bolts out?
Old Feb 24, 2011 | 04:33 PM
kihun's Avatar
kihun
Default anybody having hard time taking bolts out?
trying to change coilovers and bolt wouldn't come out because it was stuck to the metal and bushing was kept turning over. ended up cutting the bolt and the metal part was stuck on other part so we had to drill it out. anybody having same issue?
Old Feb 24, 2011 | 04:48 PM
0jiggy0's Avatar
0jiggy0
Happens sometimes. Bolts sieze, it has happened to me on hundreds of cars. Heat helps but be careful around bushings, they like to light on fire.
Old Feb 24, 2011 | 05:27 PM
Dark8lue's Avatar
Dark8lue
I think I just had a similiar problem changing suspension springs. Bolt so tight it appeared to be fused to a small peice of metal along the side of the shock. Try some PB blaster, that's what I used.
After I threaded some of the outer part of the bolt, that is. Putting a different bolt on.
Old Feb 24, 2011 | 05:58 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Cliff notes:
-A bolt wouldn't come out because it was stuck to metal.
-Cut the bolt and metal part that was stuck to another part.
-Drilled something.
Old Feb 24, 2011 | 09:21 PM
sdZ33's Avatar
sdZ33
did you try jacking up the part you were trying to take the bolt out of? That always works for me...
Old Feb 24, 2011 | 10:24 PM
terrasmak's Avatar
Nope, not on a Z. Don't know how it would happen do to the construction
etkms
Jun 19, 2022 06:30 PM
m_0g
Jun 3, 2021 10:05 AM
kyin
Oct 15, 2015 05:54 AM
TrboMike
North East
Sep 28, 2015 06:36 PM
Zergfest
Sep 23, 2015 06:03 AM
