Help with suspension please
Old Feb 27, 2011 | 06:00 PM
korAsian's Avatar
korAsian
Default Help with suspension please
I recently installed Tokico HP with GF210's and everything is great except Iam noticing a clunking/popping noise from the right rear. Sometime sounds like its from the inside of the car and then other times clearly from the outside.
Anyone have any idea of what this could be.
PS-yes everything is tight and installed correctly
Old Feb 27, 2011 | 06:15 PM
beezee's Avatar
beezee
Yes, at least that is what you think. But there is a very high chance the top nut on the shock is not tight enough. Those things can be tricky. It will not hurt to take a second look. Talking from personal experience
Old Feb 27, 2011 | 06:17 PM
korAsian's Avatar
korAsian
the nut on the shock itself ? the part that is not visible when installed
Old Feb 27, 2011 | 06:50 PM
Kuhan's Avatar
Kuhan
Yes, the nut on top of the shock can cause noise if it's not tight. You can see the nut from the engine bay by the strut bar.
Old Feb 27, 2011 | 07:47 PM
beezee's Avatar
beezee
It is the rear so the shock will have to be removed and the top nut re-tightened.
Old Feb 28, 2011 | 08:53 AM
LuciaPwNs's Avatar
LuciaPwNs
i got a sound like that from my celica. it turned out the strut blew. It was weird cause i had just installed the strut less that 1k before. If you find that everything is tight i would look into the blown strut problem.
Old Feb 28, 2011 | 11:47 AM
bmccann101's Avatar
bmccann101
had the same issues that was fixed easily.. spring collar not fully locked tight.. try that first.
Old Feb 28, 2011 | 02:08 PM
korAsian's Avatar
korAsian
Thanks for all the input guys!!!! It was the nut on top of the strut.
Now its driving perfect
Old Feb 28, 2011 | 02:22 PM
beezee's Avatar
beezee
Awesome. Good to know you got it fixed. I know the feeling
Old Mar 1, 2011 | 12:46 AM
TheFarmer's Avatar
TheFarmer
Glad you got it.
350Z_Al
Oct 29, 2020 07:44 PM
pr_350z
Oct 1, 2015 05:03 PM
