end links
Old Mar 3, 2011 | 05:59 PM
tumzilla's Avatar
tumzilla
Default end links
just got both in the rear installed and noticed I could wiggle them with my fingers side to side. is this normal for our car or are they supposed to be tight with no play?
Old Mar 3, 2011 | 06:19 PM
tyau's Avatar
tyau
Are they new stock replacement links or old aftermarket links?
There should be no play, but they should operate smooth enough that they cause very little resistance for smooth operation.
If the nuts are torqued to spec, then they should not wiggle.
Old Mar 3, 2011 | 07:16 PM
tumzilla's Avatar
tumzilla
new stock replacement links and they move side to side smoothly if I put try to wiggle them. i was told it was normal from the tech at Nissan. hrmm
Old Mar 3, 2011 | 07:26 PM
tyau's Avatar
tyau
Do they rotate at the ball joint or do they actually wiggle with play?
Wiggle is not normal. Even my worn 60k miles endlinks had no wiggle at all. They rotate with very little resistance, though.
Old Mar 3, 2011 | 07:28 PM
tumzilla's Avatar
tumzilla
only move left to right if I use very light pressure on my finger tips like if your rolling a booger with your thumb and index fingers. they don't move any other direction tho
Old Mar 3, 2011 | 07:38 PM
tyau's Avatar
tyau
That doesn't sound normal to me.
You might want to shake them harder and see if it's just the nuts not being tightened.
But then, I might be wrong. If they are new they should not have any play.
Old Mar 3, 2011 | 08:14 PM
tumzilla's Avatar
tumzilla
okay i'll get them checked out tomorrow. thank you
apex locator
Jul 23, 2021 02:27 AM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
pr_350z
Oct 1, 2015 05:03 PM
Tochigi_236
Sep 27, 2015 03:40 PM
