Stance GR+ coilovers
Old Mar 8, 2011 | 08:43 AM
gzelda's Avatar
gzelda
Default Stance GR+ coilovers
i got stance GR+ on my 350z and i was raise my car a little cause its too slammed, i was told it s pretty easy and i can jack it up and raise it. any suggestion and guidance and how to adjust it ? thank you for the help.
Old Mar 8, 2011 | 09:00 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
http://www.stance-usa.com/sus/faq
Old Mar 8, 2011 | 10:19 AM
terrasmak's Avatar
The suspension 101 thread will show you
Old Mar 8, 2011 | 10:38 AM
User 42426's Avatar
User 42426
not to thread jack, but didnt want to open up another thread just for this. My hks hypermax ls coils came without any tools to raise or lower the rear suspension. Do i need to order new tools? Or do i need to take off the spring bucket bolt everytime to access the top hap to adjust ride height? Sorry op
Old Mar 8, 2011 | 10:32 PM
cbcm2435's Avatar
cbcm2435
you do need the spanner wrench for the coilovers, you can adjust them without unbolting the spring bucket by loosening the tension on the spring and turning the threaded part, i say to loosen the spring tension just to make sure you dont loosen the bolt that holds the spring on the shock, if this happens its not fun, trust me
Old Mar 8, 2011 | 10:46 PM
Duckeee's Avatar
Duckeee
an alternative to a spanner wrench is simply a flat head screwdriver and a hammer. of course if you do this incorrectly you will chip the collars. putting a little cushion on the tip of the screwdriver helps.
Old Mar 9, 2011 | 12:25 AM
terrasmak's Avatar
A wide punch with a flat end works better, usually how i do motorcycles. Have yet to find a spanner to fit where a motorcycle rear shock is.
HoBrahYouStink
Jun 24, 2016 10:58 PM
Stevo Z
Oct 3, 2015 09:14 PM
